THE ULTIMATE PC GAMING PLATFORM
Get Game Ready with GeForce® GTX.
GeForce GTX graphics cards are the most advanced ever created. Discover unprecedented performance, power efficiency, and next-generation gaming experiences.
VR READY
Discover next-generation VR performance, the lowest latency, and plug-and-play compatibility with leading headsets—driven by NVIDIA VRWorks™ technologies. VR audio, physics, and haptics let you hear and feel every moment.
THE LATEST GAMING TECHNOLOGIES
Pascal is built to meet the demands of next generation displays, including VR, ultra-high-resolution, and multiple monitors. It features NVIDIA GameWorks™ technologies for extremely smooth gameplay and cinematic experiences. Plus, it includes revolutionary new 360-degree image capture.
PERFORMANCE
Pascal-powered graphics cards give you superior performance and power efficiency, built using ultra-fast FinFET and supporting DirectX™ 12 features to deliver the fastest, smoothest, most power-efficient gaming experiences.
VR-ready
Discover advanced VR performance, low latency, and Plug-and-Play compatibility with headsets, driven by NVIDIA VRWorks technologies. VR audio, physics, and haptics let you hear and feel every moment. -
Advanced gaming technologies
Pascal is built to meet the demands of various displays, including VR, Ultra HD, and multiple monitors. It features NVIDIA GameWorks technologies for extremely smooth gameplay and cinematic experiences. Plus, it includes a 360-degree image capture. -
Performance
Pascal-powered graphics cards give you superior performance and power efficiency, built using ultra-fast FinFET and supporting DirectX 12 features to deliver fast, smooth and power-efficient gaming experiences. -
Dual fans thermal design
Dual fans cover more area of heatsink to take heat away more efficiently.
- MSI GTX 1060 3GT OC - graphics card - GF GTX 1060 - 3 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1060
- Memory
- 3 GB GDDR5
- Core Clock
- 1544 MHz
- Boost Clock
- 1759 MHz
- Effective Memory Clock
- 8.008 GHz
- Memory Interface
- 192-bit
- Max Monitors Supported
- 3
- Interfaces Details
- DVI-D (dual link) , DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- 3.9 cm x 24.3 cm x 11.5 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1544 MHz
- Boost Clock
- 1759 MHz
- VR Ready
- 3
- API Supported
- Dual Fan Design, MSI Afterburner, Military Class 4 Components, Hi-C CAP, NVIDIA G-Sync ready, NVIDIA GameWorks, Nvidia SHIELD ready, Nvidia GeForce GTX VR Ready, HDCP
- Size
- 3 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 8.008 GHz
- Bus Width
- 192-bit
- Required Power Supply
- 400 W
- Additional Requirements
- 6 pin PCI Express power connector
- 120 Watt
- MIL-STD 810G
- 3.9 cm
- 24.3 cm
- 11.5 cm
- 556 g
