MSI H81M-E33 S1150 Intel H81 DDR3 mATX
Quicklinx: 8ZC2WS00 Mfr#: H81M-E33
Enjoy the awesome 4K UHD video playback! MSI's 8 series motherboard that equips with HDMI port(s) supports the 4K UHD (2160p ultra-high definition) signal outputs to provide an unprecedented visual experience.
  • Military Class 4
    MSI's Military Class 4 components support you while you are questing, racing, battling and shooting your way to the top. MSI's Military Class 4 components deliver record-breaking stability when you need to keep cool in the heat of battle.
  • Military Class Essentials
    The core of Military Class 4 is based on the essentials which increase your stability in the worst conditions. The humidity protection and high temperature protection ensure your system surviving each environment, no matter how harsh. The structure of the PCB limits EMI radiation. On top of that all the connectors have ESD protection in order to prevent short circuit.
  • O.C. Genie 4
    O.C. Genie 4 supercharges your speed experience! When used, O.C. Genie 4 accelerates your entire system and puts it into overdrive! Tuned by the professional overclockers, O.C. Genie 4 hands you record-breaking performance on a silver plate.
  • 4K UHD support
  • Fast Boot
    No more waiting for entering O/S! MSI Fast Boot helps to make motherboards boot lightning fast. MSI also adds the GO2BIOS button with-in. Simply click it to reset your PC and then go straight to the system BIOS.
MSI H81M-E33 - motherboard - micro ATX - LGA1150 Socket - H81
Motherboard - micro ATX
Chipset Type
Intel H81
Processor Socket
1 x LGA1150 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
16 GB
RAM Supported
2 DIMM slots - DDR3
Storage Ports
2 x SATA-600, 2 x SATA-300
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
Intel H81
Processor Socket
LGA1150 Socket
Max Processors Qty
1
Supported RAM
Max Size
16 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111G
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 240-pin , 1 x PCIe 2.0 x16 , 1 x PCIe x1
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices , SATA-300 -connectors: 2 x 7pin Serial ATA - 2 devices
1 x PS/2 keyboard , 4 x USB 2.0 , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x PS/2 mouse , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x HDMI
Internal Interfaces
2 x USB 2.0 - header , 1 x serial - header , 1 x audio - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Features
M-Flash, MSI ClickBIOS 4
Hardware Features
Audio jack detect technology, Intel Smart Connect Technology, MSI Military Class IV, Military Class Essentials, OC Genie 4, MSI Fast Boot, 4K resolution support, Clear CMOS Button
Software Included
Drivers & Utilities, MSI Live Update 5, MSI Command Center
Plug and Play
22.6 cm
17.3 cm
