- DDR4 Boost: Give your DDR4 memory a performance boost.
- VR Ready: Best virtual reality game experience without latency.
- Lightning Fast Game Experience: Turbo M.2, Intel Optane Memory Ready.
- Audio Boost: Reward your ears with studio grade sound quality for the most immersive gaming experience.
- GAMING LAN: The best online gaming experience with lowest latency and bandwidth management.
- Military Class 4, Guard-Pro: Latest evolution in high quality components for best protection and efficiency.
- Mystic Light Sync: Synchronize other RGB solutions with your gaming rig and control all LEDs in one click.
- In-Game Weapons: GAMING Hotkey, X-Boost, Xsplit Gamecaster.
Stay cool while gaming
Cooling your PC is essential for reliable performance. They have made sure to include enough fan headers with full control to allow you to cool your system any way you want. -
Be the first on the battlefield
This MSI GAMING motherboard supports all the storage standards. This allows you to connect any ultra-fast storage device, giving you in-game benefits. Start games faster, load levels faster and have a real advantage over your enemies. -
Sound that pulls you into the game
Get the most immersive sound experience when gaming. MSI Audio Boost delivers the highest sound quality through the use of premium quality audio components. This lets you enjoy breathtaking, game-changing sound to create the most exciting gameplay. -
Unmatched memory performance
MSI motherboards are crammed with features to fuel your gaming rig's memory with more speed, higher overclockability and increased stability. -
Maximize your USB device performance
Transfer your favorite games, music and movies over USB faster than ever. MSI offers a wide variety of options to connect and boost your USB 3.1 devices, delivering lightning-fast transfer speeds up to 10 Gb/s!
- MSI H270I GAMING PRO AC - motherboard - mini ITX - LGA1151 Socket - H270
- Product Type
- Motherboard - mini ITX
- Chipset Type
- Intel H270
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
- Max RAM Size
- 32 GB
- RAM Supported
- 2 DIMM slots - DDR4
- Storage Ports
- 4 x SATA-600 (RAID), 1 x M.2
- USB / FireWire Ports
- 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (2 x USB 3.1 Gen 1 + 2 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Bluetooth, Gigabit Ethernet, 802.11a/b/g/n/ac
- Product Type
- Chipset Type
- Intel H270
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR4
- Bus Clock
- 2400 MHz, 2133 MHz
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
- Audio Codec
- Realtek ALC887
- High Definition Audio
LAN
- Network Controller
- Realtek RTL8111H / Intel Dual Band Wireless-AC 8265
- Network Interfaces
- Expansion Slots
- 1 x CPU , 2 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 1 x M.2 socket
- Storage Interfaces
- SATA-600 -connectors: 4 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2
- 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 1 x DVI-D , 4 x USB 3.1 Gen 1 , 2 x USB 2.0 , 1 x PS/2 keyboard / mouse , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-in - mini-jack
- Internal Interfaces
- 2 x USB 2.0 - header , 2 x USB 3.1 Gen 1 - header , 1 x serial - header , 1 x audio - header
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector
- BIOS Features
- MSI ClickBIOS 5
- Hardware Features
- Intel Extreme Memory Profile (XMP) support, MSI Military Class IV, MSI Audio Boost, MSI Gaming Device Port, MSI Guard-Pro, Debug LED, MSI Mystic Light, MSI Steel Armor, Intel Optane Memory Ready
- Software Included
- MSI Command Center, RAMdisk, MSI Live Update 6, MSI Gaming Hotkey, MSI Gaming LAN Manager, MSI X-BOOST
- 17 cm
- 17 cm
