MSI H170A PC MATE Intel H170 S1151 DDR4 USB3.1 M.2 SATA3 ATX
Quicklinx: BLWQWS00 Mfr#: H170A PC MATE
Making your life easier is our business
The PRO Series motherboards fit in any PC. Quality you can trust with top performance and clever business solutions are key aspects of these motherboards. Make your life easier and boost your business with the super stable, reliable and long-lasting PRO Series motherboards.
CPU support - 6th Gen Intel® Core™ / Pentium® / Celeron® processors
CPU socket LGA 1151
Chipset Intel® H170 Chipset
Graphics interface - 2 x PCI-E 3.0 x16, support CrossFire™
Display interface - HDMI, DVI-D, VGA – Requires Processor Graphics
Memory support - 4 DIMMs, Dual Channel DDR4-2133MHz
Expansion slots - 3 x PCI-E x1, 2 x PCI
M.2 / SATA - 1 x Turbo M.2 32 Gb/s, 6 x SATA 6 Gb/s (2 x ports from SATA Express port)
SATA RAID - RAID 0, 1, 5, 10 – Available on SATA1 to SATA6
USB - 2 x USB 3.1 Gen2, 6 x USB 3.1 Gen1, 4 x USB 2.0
LAN - Realtek® Gigabit Ethernet
Audio - 8-channel(7.1) HD Audio with Audio Boost
  • DDR4 Boost
    With traditional memory design the memory signals are often distorted by electromagnetic signals from other components, making the system perform slower or become unstable. MSI introduces DDR4 Boost technology with optimized traces and fully isolated memory circuitry. This design ensures the memory signals stay pure for optimal performance and stability.
  • Fast storage with SATA Express
    SATA Express offers a solution in high speed storage through PCI-Express, providing more bandwidth for the latest generation SSDs up to 16 Gb/s.
  • Turbo M.2
    Delivering speeds up to 32Gb/s using Gen3 x4, Turbo M.2 is over 5 times faster than a regular SATA III connection! Enjoy a blazing fast system boot up and insanely fast loading of applications and games with MSI motherboards.
  • Secure and reliable UEFI BIOS solution
    This next generation UEFI BIOS is completely rebuilt and features a plethora of system builders' favorite options. From M-Flash for easy BIOS flashing to advanced data protection & system security, CLICK BIOS hands you the tools to fully protect and optimize the system. Through smart design and optimizations for Windows 10, CLICK BIOS is faster than ever. By reducing the use of graphics in the UEFI shell, it boots faster, reacts faster and adds a smooth experience when changing settings. Smart categorizing of functions and settings make this the easiest BIOS you'll ever see.
  • Stable, secure networking
    The Gigabit network adapter on MSI Professional motherboards offers fast, reliable and secure networking.
  • M-Cloud
    MSI M-Cloud is a convenient and secure way of saving personal files in the cloud. M-Cloud simplifies complicated settings with a user friendly interface and is easy to learn. Build and maintain your personal cloud with ease. M-Cloud can also turn your PC into an Access Point.
  • Dark Choke
    Dark Choke uses the special core design and allows the Dark Choke to run at a lower temperature with higher capacity and better power efficiency and stability.
  • Solid CAP
    With their aluminum core design, Solid CAPs are made for high-end design motherboard. Not only do Solid CAPs could provide lower Equivalent Series Resistance (ESR), but also work firmly for over-10-year.
  • Humidity protection
    Reduction in moisture absorption helps prevent "Conductive Anodic Filament". Untreated PCB's can have 10x higher failure rate.
  • High temperature protection
    All key components used in MSI motherboards have all passed military testing ensuring stable operation in the harshest environments.
  • Circuit protection
    Carefully selected materials, multiple PCB layers and shielding result in the best circuit protection for MSI motherboards.
  • ESD protection
    Each and every I/O port is protected against the hazards of Electro Static Discharge.
  • EMI protection
    All MSI motherboards comply with strict American FCC regulations and reduce the impact of Electromagnetic Interference.
  • Easy diagnostic
    MSI EZ Debug LED is an easy troubleshooting tool using 3 LEDs to indicate CPU / Memory / VGA operation every time you boot up your system. Run into trouble? Use the LEDs to easily identify the source of your problem and get back into operation quickly.
  • Enhanced CPU overvoltage protection
    Onboard overvoltage protection prevents overvoltage and short-circuit damage of the CPU and other components. A red LED near the 24 pin CPU power connector let you know that overvoltage protection is activated for easier troubleshooting.
  • CrossFire support
    This motherboard supports AMD CrossFire . Optimal PCI-Express slot placement allows for better fitting and airflow. That way, you can enjoy the best graphics at the highest framerate jumping off from your screen when running an AMD CrossFire setup.
  • Prevent damage
    Worried about damaging the PCI-Express slot or your graphics card because of the weight?
  • MSI VGA Armor
    With the increased size and weight of modern high end graphics cards, traditional PCI Express slots often show signs of bending or even breaking. Meet VGA Armor, strengthened PCI Express slots using more solder points to make sure you never have to worry about breaking off any of the slots.
  • Total Fan Control
    Total Fan Control gives you complete control of all your fans connected to the motherboard, through a revolutionary and easy to use interface.
  • Studio grade sound with Audio Boost
    With Audio Boost MSI is delivering the highest sound quality through the use of premium quality audio components. That way, you can enjoy breathtaking, crystal clear sound and music through 6-channel Audio or high impendence headphones and truly dominate the game.
  • MSI USB 3.1
    Transferring your favorite games, music and movies over USB has never been faster. USB 3.1 enables lightning fast transfer speeds up to 10Gb/s!
  • 2X front USB 3.1 Gen1
    With a clever placed USB 3.1 Gen1 front pin header, available on MSI motherboards, you can connect up to 2 USB 3.1 Gen1 devices directly to the front of your PC Chassis. This way you can easily enjoy fast USB speeds without having to use the hard-to-reach USB ports on the rear.
  • Legacy DVI / VGA video support
    To support professional monitors, TV's, beamers and other displays, this MSI motherboard features DVI and a VGA video output. No matter what screen type you want to connect, using a dedicated graphics card or an onboard connector, MSI motherboards have you covered.
  • 4K UHD
    Enjoy awesome 4K UHD (2160p ultra-high definition) video playback with MSI motherboards.
  • HDMI
    This motherboard is equipped with a HDMI port supporting the latest 4K Ultra-HD 4096×2160p resolution @ 30Hz to provide a breathtaking visual experience.
MSI H170A PC MATE - motherboard - ATX - LGA1151 Socket - Intel H170
Motherboard - ATX
Chipset Type
Intel H170
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 1 x SATA Express port, 1 x M.2
USB / FireWire Ports
2 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + (2 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel H170
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2133 MHz
Supported RAM Integrity Check
ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111H
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 2 x PCIe 3.0 x16 (x16/x4 mode) , 3 x PCIe 3.0 x1 , 2 x PCI
Storage Interfaces
SATA-600 / PCIe 3.0 -connectors: 6 x 7pin SATA, 1 x M.2, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5
RAID Features
Intel Smart Response Technology
1 x VGA , 1 x LAN (Gigabit Ethernet) , 1 x DVI-D , 2 x USB 3.1 Gen 2 , 1 x HDMI , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x PS/2 keyboard , 4 x USB 3.1 Gen 1 , 1 x PS/2 mouse
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.1 Gen 1 - header , 1 x audio - header , 1 x serial - header , 1 x parallel - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
MSI ClickBIOS, UEFI BIOS
Hardware Features
Intel Extreme Memory Profile (XMP) support, AMD CrossFireX technology support, MSI Audio Boost, Clear CMOS Button, MSI Guard-Pro, Debug LED, Turbo M.2, Turbo U.2, MSI Military Class V, MSI VGA Armor, Intel Small Business Basics support, overvoltage protection
Software Included
MSI M-Cloud
WHQL
30.4 cm
22.5 cm
