MSI H170 GAMING M3 Intel H170 S1151 DDR4 USB3.0 M.2 SATA3 ATX
Quicklinx: BLWNWS00 Mfr#: H170 GAMING M3
The MSIĀ® H170 GAMING M3 motherboard is designed to provide gamers the best gaming experience through genuine GAMING design, best-in-class gaming features and the latest technology. The H170 GAMING M3 motherboard is an engineering masterpiece tailored to gaming perfection.
DDR4 BOOST
By fully isolating the memory circuitry from other components, DDR4 Boost ensures the memory signal to stay pure for maximum performance and stability.
TURBO M.2 - GEN3 X4
Turbo M.2 delivers next generation M.2 performance through a PCI-Express 3.0 x4 interface. Delivering transfer speeds 3 times as fast as conventional M.2 solutions.
AUDIO BOOST 3 & NAHIMIC
The ultimate audio solution for gamers, powered by Nahimic Audio Enhancer. With dual OPA1652 AMPs and metal EMI Shielding you get breathtaking sound quality.
  • Unmatched memory performance and stability
    With traditional memory design the memory signals are often distorted by electromagnetic signals from other components, making the system perform slower or become unstable. MSI introduces DDR4 Boost technology with optimized traces and fully isolated memory circuitry. This design ensures the memory signals stay pure for optimal performance and stability.
  • True gaming LAN with killer
    Designed with gaming DNA, Killer LAN is optimized for championship level online and LAN eSports. The Killer E2400 Intelligent Networking Platform, featuring Advanced Stream Detect 2.0, is built for maximum networking performance for online games and high-quality streaming media. Killer LAN automatically detects and accelerates game traffic ahead of other network traffic for smoother, stutter-free in-game performance and the competitive edge.
  • Studio grade sound with Audio Boost 3
    With Audio Boost 3, powered by Nahimic Sound Technology, we're delivering the highest sound quality through the use of premium quality audio components. That way, you can enjoy breathtaking, crystal clear sound and music through 8-channel HD Audio or high impendence headphones and truly dominate the game.
  • Gaming hotkey
    Gaming Hotkey enables more functionality using your own keyboard. Simply assign functions or macros to any key and launch your favorite games, load overclocking profiles or do real-time overclocking with the push of a single button. The possibilities are endless!
  • OC essentials
    Meet the overclockers' swiss army knife; OC essentials is a set of tools that are essential to get the best performance out of your motherboard. These features increase stability, assist in trouble shooting, allow you to keep your complete system in check and allow for simple management. This way you can keep your mind on overclocking.
  • Enhanced CPU overvoltage protection
    Onboard overvoltage protection prevents overvoltage and short-circuit damage of the CPU and other components. A red LED near the 24 pin CPU power connector let you know that overvoltage protection is activated for easier troubleshooting.
  • Humidity protection
    Reduction in moisture absorption helps prevent "Conductive Anodic Filament". Untreated PCB's can have 10x higher failure rate.
  • High temperature protection
    All key components used in MSI motherboards have all passed military testing ensuring stable operation in the harshest environments.
  • Circuit protection
    Carefully selected materials, multiple PCB layers and shielding result in the best circuit protection for our GAMING motherboards.
MSI H170 GAMING M3 - motherboard - ATX - LGA1151 Socket - Intel H170
Motherboard - ATX
Chipset Type
Intel H170
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, ECC, unbuffered
Storage Ports
6 x SATA-600, 1 x SATA Express port, 1 x M.2
USB / FireWire Ports
4 x USB 3.1 Gen 1 + 4 x USB 2.0 + (2 x USB 3.1 Gen 1 + 2 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel H170
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2133 MHz
Supported RAM Integrity Check
ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
Audio Codec
Realtek ALC1150
High Definition Audio
LAN
Network Controller
Killer Gaming E2400
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 (x16 mode) , 1 x PCIe 3.0 x16 (x16 mode (x1 mode if neighbour slot is occupied)) , 2 x PCIe 3.0 x1 , 3 x PCI
Storage Interfaces
SATA-600 / PCIe 3.0 -connectors: 6 x 7pin SATA, 1 x M.2, 1 x SATA Express port
1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 1 x DVI-D , 1 x HDMI , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x PS/2 keyboard / mouse , 4 x USB 3.1 Gen 1 , 1 x TOSLINK
Internal Interfaces
2 x USB 2.0 - header , 2 x USB 3.1 Gen 1 - header , 1 x audio - header , 1 x serial - header , 1 x parallel - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
DMI support, Multilingual BIOS, UEFI BIOS, ACPI 5.0 support, SMBIOS 2.8 support, MSI ClickBIOS 5
Hardware Features
Intel Extreme Memory Profile (XMP) support, AMD CrossFireX technology support, MSI Gaming Device Port, MSI Guard-Pro, Nahimic Audio Enhacer, MSI Audio Boost 3, MSI Military Class V, LAN Protect, Double ESD Protection, OC Essentials, SteelSeries Certified (SSC), MSI VGA Armor, overvoltage protection
I/O back plate, "Do-Not-Disturb" door hanger, case badge, cable labels
Software Included
RAMdisk, MSI Gaming App, MSI Gaming Hotkey, MSI Gaming LAN Manager
Plug and Play
30.4 cm
24.4 cm
