GeForce GTX graphics cards are the most advanced ever created. Discover unprecedented performance, power efficiency, and next-generation gaming experiences.
Military class 4 components
One of the deciding factors in performance is the quality of the components used. That is why MSI only uses MIL-STD-810G certified components. Only these components have proven durable enough to withstand the torturous circumstances of extreme gaming and overclocking for extended usage. -
The future of gaming
The smoothest, fastest and most exciting gaming experience ever by eliminating screen tearing, display shutter and input lag. Ultra-high resolution (UHD) delivers 4x the resolution of 1080p content, enabling much sharper and crisper images with delicate details during gaming. -
Low profile design
Low profile design saves more spaces and can build slim or smaller system easier. -
Dual fans thermal design
Dual fans covers more area of heatsink to take heat away more efficiently.
- MSI GTX 1050 TI 4GT LP - graphics card - GF GTX 1050 Ti - 4 GB
- Graphics card - low profile
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1050 Ti
- Memory
- 4 GB GDDR5
- Core Clock
- 1290 MHz
- Boost Clock
- 1392 MHz
- Effective Memory Clock
- 7.008 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 3
- DVI-D (dual link) , DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- 3.5 cm x 18.2 cm x 6.9 cm
- Bus Type
- Graphics Engine
- Core Clock
- 1290 MHz
- Boost Clock
- 1392 MHz
- Max Resolution
- 7680 x 4320
- 3
- API Supported
- MSI Solid Capacitor, Dual Fan Design, NVIDIA Adaptive Vertical Sync, Military Class 4 Components, NVIDIA G-Sync ready, NVIDIA GameWorks, Nvidia SHIELD ready, FinFET technology, HDCP
- Size
- 4 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 7.008 GHz
- Bus Width
- 128-bit
- Required Power Supply
- 300 W
- 75 Watt
- Software Included
- MSI Afterburner
- MIL-STD 810G
- 3.5 cm
- 18.2 cm
- 6.9 cm
- 290 g
