MSI exclusive Cooler Boost 3 technology creates dual thermal modules internally by allocating dedicated heat pipes for GPU and CPU. One click on the fan boost button, a total of 6 heat pipes and dual fans actively and effectively push heat out of the system. MSI True Color technology guarantees that each panel in MSI notebook provides fine precision in color. Hence, each color is delivered with high standard precision in detail, guaranteeing excellent color fidelity for many use applications. Expand the vision for extreme gaming experience. Embrace immersive gaming experience by expanding your gaming real estate across 3 external displays. MSI gaming notebook built in high quality wide-view angle display takes image clarity to a high level with higher pixel resolution. Images are more sharp and vivid in contrast level and clearer in brightness level. Hence, images are more vivid even from left and right side of the viewing angle. When you're playing games, you will have breathtaking and brilliantly true-to-life viewing experience.
Push the limits of your audio peripherals and hear the difference with the SABRE audio DAC. Discover details that you've been missing or maintain the upper-hand in competitive FPS matches where every bit of sound counts. Originally developed for military fighter jets, Nahimic specializes in 3D sound software processing and audio improvements offering virtual 7.1 sound in immersive high definition. Designed to work with standard audio and stereo equipment, Nahimic transports gamers into the action, allowing them to sense every footstep, hear every bullet whizzing past, and feel every explosion. It also features a high definition audio recorder to easily capture and stream studio quality sound. The GT72 is packing advanced Dynaudio design with 2 channels with 1 subwoofer, and its absolutely authentic hearing experience. People who play games or enjoy movies will absolutely be immersed in the perfect system with outstanding sound effect.
Every hardware detail of this keyboard is calculated and especially designed for professional gamers' needs. Better responsive and tactile feedback, optimum WASD zone and support of multi-key inputs are all for gamers to gain full command over gaming missions. Stop losing games to lag with Killer DoubleShot Pro. Protect and prioritize networking traffic while preventing lag spikes so you can game without fear and play at your best. Select programs you want your network to prioritize to ensure maximum bandwidth and track your speeds. Killer DoubleShot Pro supports both Killer Gb LAN and Wi-Fi 802.11ac dual band protocol and improves average latency.
Cooler Boost 3
MSI exclusive Cooler Boost 3 technology creates dual thermal modules internally by allocating dedicated heat pipes for GPU and CPU. One click on the fan boost button, a total of 6 heat pipes and dual fans actively and effectively push heat out of the system. -
MSI True Color technology guarantees that each panel in MSI notebook provides fine precision in color. Hence, each color is delivered with high standard precision in detail, guaranteeing excellent color fidelity for many use applications. -
Matrix Display
Expand the vision for extreme gaming experience. Embrace immersive gaming experience by expanding your gaming real estate across 3 external displays. -
Wide viewing angle display
MSI gaming notebook built in high quality wide-view angle display takes image clarity to a high level with higher pixel resolution. Images are more sharp and vivid in contrast level and clearer in brightness level. Hence, images are more vivid even from left and right side of the viewing angle. When you're playing games, you will have breathtaking and brilliantly true-to-life viewing experience. -
ESS SABRE HiFi audio DAC
Push the limits of your audio peripherals and hear the difference with the SABRE audio DAC. Discover details that you've been missing or maintain the upper-hand in competitive FPS matches where every bit of sound counts. -
Nahimic virtual surround sound
Originally developed for military fighter jets, Nahimic specializes in 3D sound software processing and audio improvements offering virtual 7.1 sound in immersive high definition. Designed to work with standard audio and stereo equipment, Nahimic transports gamers into the action, allowing them to sense every footstep, hear every bullet whizzing past, and feel every explosion. It also features a high definition audio recorder to easily capture and stream studio quality sound. -
Sound by Dynaudio
The GT72 is packing advanced Dynaudio design with 2 channels with 1 subwoofer, and its absolutely authentic hearing experience. People who play games or enjoy movies will absolutely be immersed in the perfect system with outstanding sound effect. -
A keyboard all gamers desire for
Every hardware detail of this keyboard is calculated and especially designed for professional gamers' needs. Better responsive and tactile feedback, optimum WASD zone and support of multi-key inputs are all for gamers to gain full command over gaming missions. -
- MSI GT72S 6QE 612UK Dominator Pro G - 17.3" - Intel Core i7 - 6820HK - 32 GB RAM - 256 GB SSD x 2 + 1 TB HDD
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Core i7 (6th Gen) - 6820HK / 2.7 GHz, up to 3.6 GHz / 8 MB Cache
- Memory
- 32 GB DDR4 (2 x 16 GB)
- Storage
- 1.512 TB: 2 x 256 GB SSD - Super RAID 4, NVMe + 1 TB HDD / 7200 rpm
- Optical Drive
- Blu-ray Writer
- Display
- 17.3" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA GeForce GTX 980M
- Video Memory
- 8 GB GDDR5 SDRAM
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 9-cell
- Matte black, brushed metal
- 42.8 cm x 29.4 cm x 4.8 cm
- 3.78 kg
- Environmental Standards
- - EPEAT Climate+
- Limited warranty - 2 years
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6820HK / 2.7 GHz
- Max Turbo Speed
- 3.6 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- Chipset
- Mobile Intel CM236 Express
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 32 GB (2 x 16 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 4
- Empty Slots
- 2
Storage
- Total Capacity
- 1.512 TB
- Main Storage
- 2 x 256 GB SSD M.2 PCIe - MSI Super RAID 4, NVM Express (NVMe)
- Secondary Storage
- 1 TB HDD SATA 6Gb/s / 7200 rpm
- RAID Level
- RAID 0
- Optical Drive
- BD-Writer
Display
- 17.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Anti-glare, WideView, MSI Matrix Display, NVIDIA G-SYNC compatible, MSI True Colour Technology
Audio & Video
- Graphics Processor
- Video Memory
- 8 GB GDDR5 SDRAM
- Camera
- Yes - 1080p
- Sound
- Stereo speakers, subwoofer, microphone
- Audio Features
- Output: Dynaudio Premium Sound Technology, Nahimic sound technology, ESS SABRE HiFi audio DAC technology
Input
- Keyboard, touchpad
- SteelSeries Engine technology, SteelSeries Full Color
Communications
- Wireless
- Wireless Controller
- M.2 Card
- Network Interface
- Gigabit Ethernet
- Killer DoubleShot Pro Technology, Smart Teaming, Killer Shield, Advanced Stream Detect 2.0
- Technology
- 9-cell
AC Adapter
- Output
- 230 Watt
Connections & Expansion
- Interfaces Details
- LAN , Microphone input , Headphone output , 6 x USB 3.0 , HDMI , Mini DisplayPort , Audio line-in , Audio line-out , USB-C
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- SteelSeries Engine, XSplit Gamecaster 2 (1 year Premium licence)
- SteelSeries gaming keyboard, Cooler Boost 3 technology, MSI SHIFT Technology
- Included Accessories
- Power adapter
- 3.78 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
