Get the optimal performance out of your notebook with support of the advanced DDR4-2133 memory, achieving high speeds in reading and writing. With fast performance this laptop takes your to extreme gaming experience. See gaming differently with breakthrough NVIDIA G-SYNC display technology. By synchronizing the display refresh rates to the GPU, G-GYNC eliminates screen tearing and minimizes stutter and input lag to deliver advanced gaming experience. Objects look sharper and gameplay is fluid and responsive to give you a serious competitive edge. MSI True Color technology guarantees that each panel in a MSI notebook comes with fine precision in color. Each color is delivered with high precision in detail, guaranteeing excellent color fidelity for many use applications.
One port for everything
Transfer massive files faster than ever with high transfer rates. Get more pixel power supporting dual 4K displays and extend your field of view with daisy chain capabilities. Even charge your phones, tablet and any device faster on-the-go or at home. -
Cooler Boost 3
MSI Cooler Boost 3 technology creates dual thermal modules internally by allocating dedicated heat pipes for GPU and CPU. One click on the fan boost button, a total of 6 heat pipes and dual fans actively and effectively push heat out of the system, making the cooling design of GT72 optimal. -
DDR4-2133 memory support
Get the best possible performance out of your notebook with support of the advanced DDR4-2133 memory, achieving high speeds in reading and writing. -
NVIDIA G-SYNC
See gaming differently with NVIDIA G-SYNC display technology. By synchronizing the display refresh rates to the GPU, G-GYNC eliminates screen tearing and minimizes stutter and input lag to deliver advanced gaming experience. Objects look sharper and gameplay is fluid and responsive to give you a serious competitive edge. -
MSI True Color technology guarantees that each panel in a MSI notebook comes with a fine precision in color. Each color is delivered with the high precision in detail, guaranteeing excellent color fidelity for many use applications. -
True Color Profile
Besides Gaming mode, True Color technology offers advanced color accuracy for several scenarios. Work or play, you can easily switch to the mode that suits your eyes. The profile sharing feature permits you to share your True Color settings to other users anywhere. -
Matrix Display
Expand the vision for extreme gaming experience. Embrace immersive gaming experience by expanding your gaming real estate across 3 external displays in Full HD with the Surround View mode of MSI Matrix Display technology. -
Nahimic Surround Sound
Designed to work with audio and stereo equipment, Nahimic transports gamers into the action, allowing them to sense every footstep, hear every bullet whizzing past, and feel every explosion. It also features a high definition audio recorder to easily capture and stream studio quality sound. -
A keyboard all gamers desire for
Every hardware detail of this keyboard is calculated and designed for professional gamers' needs. Better responsive and tactile feedback, optimum WASD zone and support of multi-key inputs are all for gamers to gain full command over gaming missions. -
Killer DoubleShot Pro
Stop losing games to lag with Killer DoubleShot Pro. Protect and prioritize networking traffic while preventing lag spikes so you can game without fear. Select programs you want your network to prioritize to ensure high bandwidth and track your speeds with the easy-to-use Killer Networking Manager.
- MSI GT72 6QD 048UK Dominator G - 17.3" - Intel Core i7 6700HQ - 16 GB RAM - 128 GB SSD + 1 TB HDD
- Product Type
- Notebook
- Operating System
- Windows 10 Home
- Processor
- Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz (3.5 GHz) / 6 MB Cache
- Memory
- 16 GB DDR4 (2 x 8 GB)
- Storage
- 128 GB SSD + 1 TB HDD / 7200 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 17.3" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA GeForce GTX 970M
- Video Memory
- 3 GB GDDR5 SDRAM
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 9-cell
- Black
- 42.8 cm x 29.4 cm x 4.8 cm
- 3.78 kg
- Limited warranty - 2 years
- Product Type
- Notebook
- Operating System
- Windows 10 Home
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Chipset
- Mobile Intel HM170
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 16 GB (2 x 8 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 4
- Empty Slots
- 2
Storage
- Main Storage
- 128 GB SSD M.2 PCIe
- Secondary Storage
- 1 TB HDD SATA 6Gb/s / 7200 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
Display
- 17.3" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Anti-glare, WideView, MSI Matrix Display, NVIDIA G-SYNC compatible, MSI True Colour Technology
Audio & Video
- Graphics Processor
- Video Memory
- 3 GB GDDR5 SDRAM
- Camera
- Yes - 1080p
- Sound
- Stereo speakers, subwoofer, microphone
- Audio Features
- Output: 7.1 SPDIF, Dynaudio Premium Sound Technology, Nahimic sound technology, ESS SABRE HiFi audio DAC technology
Input
- Keyboard, touchpad
- SteelSeries Full Color
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Killer DoubleShot Pro Technology, Smart Teaming, Killer Shield
- Technology
- 9-cell Lithium Ion
- Capacity
- 83 Wh
AC Adapter
- Output
- 230 Watt, 19.5 V
Connections & Expansion
- LAN , Microphone input , Headphone output , 6 x USB 3.0 , HDMI , Mini DisplayPort , Audio line-out , Audio line-in , USB-C
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- MSI BurnRecovery, Norton Online Backup (30 days trial), Norton Internet Security (60 days trial), MSI Battery Calibration, Skype (Metro UI), Fresh Paint (Metro UI), Norton Anti-Theft (30 days trial), EverNote (Metro UI), Microsoft Office 2013 (30 days trial), MSI Boot Configure, MSI Dragon Gaming Center, Bewise CookBook (Metro UI), Green Field Puzzle (Metro UI), Hit Hot TuMetro (Metro UI), Corel Winzip, MSI System Control Manager, Norton Studio (Metro UI), MSI Super Charger, WildTangent Game App (Metro UI), Microsoft Essential 2012, Microsoft Wordament (Metro UI), Microsoft Game Pack (Metro UI), MAGIX Music Maker Silver
- Black
- SteelSeries gaming keyboard, Cooler Boost 3 technology, MSI SHIFT Technology
- Included Accessories
- Power adapter
- 3.78 kg
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
