Get optimal performance out of your notebook with support of the advanced DDR4-2133 memory, achieving high reading and writing speeds. With fast performance DDR4-2133 takes your extreme gaming experience to the next level. Transfer massive files faster with high transfer rates. Get more pixel power supporting dual 4K displays and extend your field of view with daisy chain capabilities. Even charge your phones, tablet and any device faster on-the-go or at home.
Cooler Boost 3: keep calm under pressure
MSI Cooler Boost 3 technology creates dual thermal modules internally by allocating dedicated heat pipes for GPU and CPU. A total of 4 heat pipes and dual fans actively and effectively push heat out of the system. -
SHIFT technology
The MSI SHIFT technology boosts the system while minimizing noise and temperature. Switch between three profiles to reach balance between system performance and comfortable user experience. -
One port for everything
Transfer massive files faster with high transfer rates. Get more pixel power supporting dual 4K displays and extend your field of view with daisy chain capabilities. Even charge your phones, tablet and any device faster on-the-go or at home. -
DDR4-2133 memory support
Get optimal performance out of your notebook with support of the advanced DDR4-2133 memory, achieving high reading and writing speeds. With fast performance DDR4-2133 takes your extreme gaming experience to the next level. -
True Color technology
MSI True Color technology guarantees that each panel in a MSI notebook comes with a fine precision in color. Each color is delivered with high precision in detail, guaranteeing excellent color fidelity for many use applications. -
True Color profile
The True Color technology offers great color accuracy for several scenarios. Work or play, you can easily switch to the mode that suits your eyes. The profile sharing feature permits you to share your True Color settings to other users anywhere. -
Matrix display
MSI Matrix Display supports up to 3 external displays simultaneously. Multitask is made possible even during competitive gameplays. Connect the laptop to HDTV display, Matrix Display supports 4K output. -
Nahimic Surround Sound
Nahimic transports gamers into the action, allowing them to sense every footstep, hear every bullet whizzing past, and feel every explosion. It also features a high definition audio recorder to easily capture and stream studio quality sound. -
Sound by Dynaudio
Enjoy asvanced audio features that create a realistic sound and immersive effects. Dynaudio delivers an authentic sound experience by boosting power amplitude. -
Audio Boost
The MSI Audio Boost design enhances the output sound detail and sound stage. The gold flash audio jack provides stable sound transmission and works in conjunction with the optimized headsets AMP design, characterized by low noise and low distortion, to greatly enhance headphone performance and faithfully reproduce each acoustic detail. -
A keyboard all gamers desire for
Every hardware detail of this keyboard is calculated and especially designed for professional gamers' needs. Responsive and tactile feedback, optimum WASD zone and support of multi-key inputs are all for gamers to gain full command over gaming missions.
- MSI GS60 6QE 063UK Ghost Pro - 15.6" - Core i7 6700HQ - 8 GB RAM - 128 GB SSD + 1 TB HDD
- Product Type
- Notebook
- Operating System
- Windows 10 Home
- Processor
- Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz (3.5 GHz) / 6 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 128 GB SSD + 1 TB HDD / 7200 rpm
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA GeForce GTX 970M
- Video Memory
- 3 GB GDDR5 SDRAM
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 6-cell
- Black
- 39 cm x 26.6 cm x 2.005 cm
- 2 kg
- Limited warranty - 2 years
- Product Type
- Notebook
- Operating System
- Windows 10 Home
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Chipset
- Mobile Intel HM170
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 128 GB SSD M.2 SATA
- Secondary Storage
- 1 TB HDD SATA 6Gb/s / 7200 rpm
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- WideView, MSI Matrix Display, MSI True Colour Technology
Audio & Video
- Graphics Processor
- Video Memory
- 3 GB GDDR5 SDRAM
- Camera
- Yes - 1080p
- Sound
- Stereo speakers, microphone
- Audio Features
- Output: 7.1 SPDIF, Dynaudio Premium Sound Technology, MSI Audio Boost, Nahimic sound technology, ESS SABRE HiFi audio DAC technology
Input
- Keyboard, touchpad
- SteelSeries Engine technology, SteelSeries Full Color
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Killer DoubleShot Pro Technology, Smart Teaming
- Technology
- 6-cell
- Capacity
- 47.31 Wh
AC Adapter
- Output
- 150 Watt, 19.5 V, 7.7 A
Connections & Expansion
- LAN , HDMI , Microphone input , Headphone output , USB-C , Mini DisplayPort , 2 x USB 3.0
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- MSI BurnRecovery, Norton Online Backup (30 days trial), MAGIX Video Easy SE, Norton Internet Security (60 days trial), MSI Battery Calibration, Skype (Metro UI), Norton Anti-Theft (30 days trial), GeForce Experience, EverNote (Metro UI), XSplit Gamecaster, Microsoft Office 2013 (30 days trial), MSI Boot Configure, MSI Dragon Gaming Center, Bewise CookBook (Metro UI), Green Field Puzzle (Metro UI), Hit Hot TuMetro (Metro UI), Corel Winzip, MSI System Control Manager, Norton Studio (Metro UI), MSI Super Charger, WildTangent Game App (Metro UI), Microsoft Essential 2012, Microsoft Fresh Paint (Metro UI), Microsoft Wordament (Metro UI), Microsoft Game Pack (Metro UI), MAGIX Music Maker Jam (Metro UI) (30 days trial), MAGIX Music Maker Silver, MAGIX Photo Manager MX, MAGIX Web Designer Silver
- Black
- SteelSeries gaming keyboard, Cooler Boost 3 technology, MSI SHIFT Technology
- Included Accessories
- Power adapter
- 2 kg
