The improved processor requires lower power consumption but delivers better performance. The exclusive SHIFT technology pushes system to the extreme while minimizing noise and temperature. Switch between three profiles "Sport," "Comfort," and "Green" to reach balance between system performance and comfortable user experience.
Super port - one port for everything
Whatever you need, you can get it done with just one port. Transfer massive files faster with high transfer rates. Get more pixel power supporting dual 4K displays and extend your field of view with daisy chain capabilities. Even charge your phones, tablet and any device faster on-the-go or at home. -
Connect 4K
Output dual 4K displays with single port. Enjoy your game with double sensation. -
Advanced architecture memory support
Get the optimal performance out of your notebook with support of the advanced memory, achieving fast reading and writing speeds. With faster performance, improved memory helps to take your extreme gaming experience to another level. -
Cooler Boost 3: keep calm under pressure
Cooler Boost 3 technology creates dual thermal modules internally by allocating dedicated heat pipes for GPU and CPU. Heat pipes and dual fans actively and effectively push heat out of the system, resulting in better cooling effects on this incredible slim and light gaming notebook. -
Insanely powerful discrete graphics card
The graphics card brings extreme graphics performance to this serious gaming notebook. It delivers extremely fast and fluid gameplay at the high settings and resolutions in a lightweight and portable design. -
True Color technology
True Color technology guarantees that each panel in this notebook comes with the fine precision in color. After examination and an extensive factory calibration process by the True Color technology, the panel quality will be more accurate, close to sRGB. Hence, each color is delivered with the high precision in detail, guaranteeing excellent color fidelity for many use applications. -
True Color profile
Vision and sound are the extremely important two factors in this field. You get to see clearer than your enemies to always get one step ahead of the rest. True Color technology also offers perfect color accuracy for more scenarios. Work or play, you can easily switch to the mode that optimally suits your eyes. The profile sharing feature permits you to share your True Color settings to other users anywhere. -
Matrix Display
Expand the vision for extreme gaming experience. Matrix Display supports external displays simultaneously. Multi-task is made possible even during competitive gameplays. Connect the laptop to HDTV display, Matrix Display supports 4K output with a high resolution. Matrix Display technology creates an ideal environment for extreme gaming experience and pleasant multimedia entertainment. -
ESS SABRE audio DAC - evolve details you hear
Push the limits of your audio peripherals and hear the difference with the SABRE Audio DAC. Support high sampling rate. Discover details that you've been missing or maintain the upper-hand in competitive FPS matches where every bit of sound counts. -
Sound by Dynaudio
To satisfy consumers desire to experience high quality sound effects, MSI equips this gaming notebook with excellent audio features, creating a realistic sound and immersive effects. Dynaudio delivers an authentic sound experience by boosting power amplitude, meaning a volume increase. Any high quality stereo source is transformed into true-to-life, multi-channel sound. No need to purchase extra speakers, wires or speaker stands to appreciate room-filling sound. -
The real deal: a keyboard all gamers desire for
Every hardware detail of this keyboard is calculated and especially designed for professional gamers' needs. Better responsive and tactile feedback, optimum WASD zone and support of multi-key inputs are all for gamers to gain full command over gaming missions.
- MSI GS40 6QE 027UK Phantom - 14" - Intel Core i7 - 6700HQ - 8 GB RAM - 128 GB SSD + 1 TB HDD
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Core i7 (6th Gen) - 6700HQ / 2.6 GHz, up to 3.5 GHz / 6 MB Cache
- Memory
- 8 GB DDR4
- Storage
- 128 GB SSD + 1 TB HDD / 7200 rpm
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA GeForce GTX 970
- Video Memory
- 3 GB GDDR5 SDRAM
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 4-cell
- 34.5 cm x 24.5 cm x 2.28 cm
- 1.6 kg
- Environmental Standards
- Limited warranty - 2 years - pick-up and return
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Chipset
- Mobile Intel HM170
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
Storage
- Main Storage
- 128 GB SSD M.2
- Secondary Storage
- 1 TB HDD SATA 6Gb/s / 7200 rpm
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- WideView, MSI Matrix Display, MSI True Colour Technology
Audio & Video
- Graphics Processor
- Video Memory
- 3 GB GDDR5 SDRAM
- Camera
- Yes - 1080p
- Sound
- Stereo speakers, microphone
- Audio Features
- Output: 7.1 SPDIF, Dynaudio Premium Sound Technology, Nahimic sound technology, ESS SABRE HiFi audio DAC technology
Input
- Keyboard, touchpad
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Killer DoubleShot Pro Technology, Smart Teaming, Killer Shield
- Technology
- 4-cell
AC Adapter
- Output
- 150 Watt
Connections & Expansion
- Interfaces Details
- USB-C , 2 x USB 3.0 , LAN , Mini DisplayPort , Headphone output , Microphone input , HDMI
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- SteelSeries Engine 3, XSplit Gamecaster 2 (1 year Premium licence)
- SteelSeries gaming keyboard, Cooler Boost 3 technology, MSI SHIFT Technology
- Included Accessories
- Power adapter
- 1.6 kg
Sustainability Information
- TCO Certified
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
