MSI GeForce GTX 760 1006MHz 2GB PCI-Express 3.0 HDMI OC
Quicklinx: 8SY6WS00 Mfr#: N760-2GD5/OC
  • NVIDIA GeForce GTX 760
  • DisplayPort
  • High-Definition Multimedia Interface (HDMI)
1 on order, delivery delayed
A graphics card is the single most important element for more FPS. As gamers, MSI understand that not just any graphics card "will do". That's why MSI bring you the best of the best. MSI don't want to bug you with noise and heat, but MSI do want to give you more performance. With MSI Gaming series graphics cards you get just that.
Most MSI Gaming graphics cards come pre-overclocked out of the factory. This simply means you get more performance out of your card, without spending any time on checking for maximum clocks and stability.
  • Pre overclocked
  • Advanced Twin Frozr IV
    MSI's Twin Frozr has been the industry defining graphics card cooler. The first Twin Frozr kicked of the dual-fan trend and today MSI stays true to its dual-fan dual-slot design where others have to resort to less effective means. The other part that the Twin Frozr cooler uses is a large aluminum fin grid array that provides a huge amount of surface area for cooling. Heat from the GPU is transferred to the fin grid array by virtue of heat pipes with MSI's special SuperPipe technology. SuperPipes transfer heat twice as fast as regular heat pipes enabling an MSI Gaming graphics card to stay cooler than the competition.
  • Military class component
    One of the deciding factors in performance is the quality of the components used. That is why MSI only uses MIL-STD-810G certified components for its Gaming cards because only these components have proven to be able to withstand the torturous circumstances of extreme gaming and overclocking.
  • Hi-c CAP
    A Hi-c CAP is a very small, but super-efficient capacitor. Besides ensuring enough spacing around a CPU socket to install large coolers, it also allows for 93% energy efficiency. Thanks to Hi-c CAP's MSI mainboards are the most energy efficient in the market.
  • Solid CAP
    One With their aluminum core design, Solid CAP's have been a staple in high-end design mainboard designs and provides lower Equivalent Series Resistance (ESR) as well as its over-10-year lifespan.
  • Super Ferrite Chokes
    Super Ferrite Chokes use a Ferrite core that is Super-Permeable. This allows the Super Ferrite Chokes to run at a 35 degree Celsius lower temperature, have a 30% higher current capacity, a 20% improvement in power efficiency and better overclocking power stability.
  • Afterburner
    MSI Afterburner has quickly become the favorite overclocking software for media, overclockers and end-users. Because of its simple interface, it's easy to learn, but it packs a lot of powerful features like an integrated benchmark utility called Kombustor that can check your system performance in benchmarking mode, or run as a stability test.
MSI N760-2GD5/OC - graphics card - GF GTX 760 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
2 GB GDDR5
Core Clock
1006 MHz
Boost Clock
1072 MHz
CUDA Cores
1152
Effective Memory Clock
6.008 GHz
Memory Interface
256-bit
Max Monitors Supported
4
DVI-I (dual link) , DVI-D (dual link) , HDMI , DisplayPort , VGA - with adapter
API Supported
DirectX 11.1, OpenGL 4.3
3.8 cm x 24.2 cm x 11.1 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1006 MHz
Boost Clock
1072 MHz
CUDA Cores
1152
4
API Supported
MSI Solid Capacitor, Nvidia 3-way SLI ready, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision Surround Ready, NVIDIA GPU Boost 2.0
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
6.008 GHz
Bus Width
256-bit
170 Watt
2 x 6 pin power cables
1 x DVI-VGA adapter
Software Included
Drivers & Utilities, MSI Afterburner
3.8 cm
24.2 cm
11.1 cm
