The GeForce GTX 1080 Ti is truly unique. Designed and built by NVIDIA. Crafted with premium materials and components, including a die-cast aluminum body and 7-phase dualFET power supply. And cooled by a radial fan with an advanced vapor chamber designed for consistent performance in even the most thermally challenging environments.
The GeForce GTX 1080 Ti is NVIDIA's flagship gaming GPU, based on the NVIDIA Pascal architecture. The latest addition to the ultimate gaming platform, this card is packed with extreme gaming horsepower, next-gen 11 Gbps GDDR5X memory, and a massive 11 GB frame buffer.
Innovative design
The GeForce GTX 1080 Ti is truly unique. Designed and built by NVIDIA. Crafted with premium materials and components, including a die-cast aluminum body and 7-phase dualFET power supply. And cooled by a radial fan with an advanced vapor chamber designed for consistent performance in even the most thermally challenging environments. -
Ultimate GeForce
The GeForce GTX 1080 Ti is NVIDIA's flagship gaming GPU, based on the NVIDIA Pascal architecture. The latest addition to the ultimate gaming platform, this card is packed with extreme gaming horsepower, next-gen 11 Gbps GDDR5X memory, and a massive 11 GB frame buffer. -
Performance
The GeForce GTX 1080 Ti graphics card gives you amazing speed and power efficiency.
- MSI GTX 1080 Ti GAMING X 11G - graphics card - GF GTX 1080 Ti - 11 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1080 Ti
- Memory
- 11 GB GDDR5X
- Core Clock
- 1569 MHz
- Boost Clock
- 1683 MHz
- CUDA Cores
- 3584
- Effective Memory Clock
- 11.124 GHz
- Memory Interface
- 352-bit
- Max Monitors Supported
- 4
- Interfaces Details
- 2 x DisplayPort , 2 x HDMI , DVI-D (dual link)
- API Supported
- DirectX 12, OpenGL 4.5
- 5.1 cm x 29 cm x 14 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1569 MHz
- Boost Clock
- 1683 MHz
- CUDA Cores
- 3584
- VR Ready
- 4
- API Supported
- Nvidia 2-way SLI ready, MSI Afterburner, NVIDIA Adaptive Vertical Sync, NVIDIA G-Sync ready, MSI Zero Frozr technology, Nvidia GeForce GTX VR Ready, Torx 2.0 Fans, HDCP
- Size
- 11 GB
- Technology
- GDDR5X SDRAM
- Effective Clock Speed
- 11.124 GHz
- Bus Width
- 352-bit
- Required Power Supply
- 600 W
- Additional Requirements
- 2 x 8 pin PCI Express power connector
- 250 Watt
- Software Included
- MSI Afterburner, MSI Gaming App
- DisplayPort 1.4, HDCP 2.2
- 5.1 cm
- 29 cm
- 14 cm
- 1.257 kg
