MSI GeForce GTX 1080Ti ARMOR OC 11GB GDDR5X PCIe Graphics Card
Quicklinx: CVCRWS00 Mfr#: GTX 1080 Ti ARMOR 11G OC
  • High-Definition Multimedia Interface (HDMI)
  • DisplayPort
Game in style and dare to be different with MSI's unique ARMOR graphics cards. Inspired by advanced armor shielding with a classy finish, ARMOR graphics cards are perfect for gamers and case modders, who are looking for something different. This is where gaming meets class.
  • Dual fan
    Armor 2X thermal design is equipped with two of the MSI TORX fans. Thanks to the blade design, MSI TORX fans provide strong cooling performance, while remaining incredibly silent.
  • ZeroFrozr - stay undetected
    ZeroFrozr technology eliminates fan noise by stopping the fans in low-load situations. This means you can focus on gaming without the noise of spinning fans.
  • Heatsink and airflow control
    Under the classy shroud and powerful dual fans is a huge heatsink with countless aluminum fins, that help dissipate the heat from the GPU. The copper heatpipes are infused in the baseplate to ensure efficient cooling. The aluminum fins are rigged with airflow control technology to maximize airflow towards the heatpipes.
  • Prepare for VR with MSI
    To experience and enjoy the impressive world of virtual reality, high-performance hardware is required. MSI provides the right advice to make sure your system is VR ready. Integrating the advanced technologies in recommended MSI VR gaming hardware for smooth performance. Together with VR partners, MSI brings gamers an extremely realistic VR experience, where games come alive.
MSI GTX 1080 Ti ARMOR 11G OC - graphics card - GF GTX 1080 Ti - 11 GB - black, white
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1080 Ti
11 GB GDDR5X
Core Clock
1531 MHz
Boost Clock
1645 MHz
CUDA Cores
3584
Effective Memory Clock
11.016 GHz
Memory Interface
352-bit
Max Monitors Supported
4
Interfaces Details
2 x DisplayPort , 2 x HDMI , DVI-D (dual link)
API Supported
DirectX 12, OpenGL 4.5
4 cm x 29 cm x 14.3 cm
Enclosure Colour
Black, white
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1531 MHz
Boost Clock
1645 MHz
CUDA Cores
3584
VR Ready
4
Interfaces Details
API Supported
Nvidia 2-way SLI ready, MSI Afterburner, NVIDIA Adaptive Vertical Sync, NVIDIA G-Sync ready, Armor 2X Thermal Design, MSI Zero Frozr technology, Nvidia GeForce GTX VR Ready, HDCP
Size
11 GB
GDDR5X SDRAM
Effective Clock Speed
11.016 GHz
Bus Width
352-bit
Required Power Supply
600 W
Additional Requirements
2 x 8 pin PCI Express power connector
250 Watt
Software Included
MSI Afterburner
HDCP 2.2
4 cm
29 cm
14.3 cm
903 g
Enclosure Colour
Black, white
