MSI GeForce GTX 1080 Founders Edition 8GB GDDR5 Graphics Card
Quicklinx: C4QJWS00 Mfr#: GTX-1080-FOUNDERS-ED
GeForce® GTX 1080 Founders Edition
Core/Memory:
1607MHz Core (Boost Clock:1733MHz)
8GB GDDR5X 10010 MHz Memory
Video Output Function:
DisplayPort x 3
HDMI x 1
Dual-link DVI-D x 1
Features:
Virtual Reality Ready
GEFORCE Experience
G-Sync
THE ULTIMATE PC GAMING PLATFORM
Get Game Ready with GeForce® GTX.
GeForce GTX graphics cards are the most advanced ever created. Discover unprecedented performance, power efficiency, and next-generation gaming experiences.
THE ULTIMATE GRAPHICS FOR VIRTUAL REALITY
NVIDIA’s unique set of features ensure you get the right level of performance, image quality, and latency to ensure your VR experience is nothing short of amazing
A BETTER GAMING EXPERIENCE
The easiest way to update your drivers, optimize your games, and share your victories
STUTTER, TEAR-FREE GAMEPLAY
Synchronizes the display refresh to your GeForce GTX GPU for the fast, smooth gaming
NVIDIA’s new flagship GeForce GTX 1080 is the most advanced gaming GPU ever created. Powered by the new NVIDIA Pascal™ architecture, this breakthrough GPU delivers industry-leading performance, innovative new gaming technologies, and immersive, next-gen VR.
Performance:
The GeForce GTX 1080 is a quantum leap in performance and power efficiency. It’s built using ultra-fast FinFET and high-bandwidth GDDR5X technologies, and supports DirectX 12 features for the fastest, smoothest, most power-efficient gaming experiences.
Next-Gen Gaming Technologies:
GeForce GTX 1080 uses the power of Pascal to meet the demands of the latest displays, including VR, ultra-high-resolution, and multiple monitors. It features NVIDIA GameWorks™ technologies for smooth gameplay and cinematic experiences, as well as revolutionary 360-degree image capture—even in VR.
VR READY:
Discover next-generation VR performance, the lowest latency, and plug-and-play compatibility with leading headsets—driven by NVIDIA VRWorks™ technologies. VR audio, physics, and haptics let you hear and feel every moment.
  • Performance
    The GeForce GTX 1080 is a quantum leap in performance and power efficiency. It's built using ultra-fast FinFET and high-bandwidth GDDR5X technologies, and supports DirectX 12 features for the fastest, smoothest, most power-efficient gaming experiences.
  • Next-gen gaming technologies
    GeForce GTX 1080 uses the power of Pascal to meet the demands of the latest displays, including VR, ultra-high-resolution, and multiple monitors. It features NVIDIA GameWorks technologies for smooth gameplay and cinematic experiences, as well as revolutionary 360-degree image capture - even in VR.
  • VR ready
    Discover next-generation VR performance, the lowest latency, and plug-and-play compatibility with leading headsets - driven by NVIDIA VRWorks technologies. VR audio, physics, and haptics let you hear and feel every moment.
  • Groundbreaking design
    The GeForce GTX 1080 is meticulously crafted to offer superior heat dissipation using an advanced vapor chamber and premium materials, so it runs as cool as it looks.
MSI GTX 1080 - Founders Edition - graphics card - GF GTX 1080 - 8 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1080
8 GB GDDR5X
Core Clock
1607 MHz
Boost Clock
1733 MHz
Effective Memory Clock
10.01 GHz
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
DVI-D (dual link) , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
4 cm x 26.9 cm x 11.1 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1607 MHz
Boost Clock
1733 MHz
VR Ready
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
Nvidia SLI Multi-GPU Technology, Nvidia 2-way SLI ready, NVIDIA G-Sync ready, NVIDIA GameWorks, Nvidia GeForce GTX VR Ready, HDCP
Size
8 GB
GDDR5X SDRAM
Effective Clock Speed
10.01 GHz
Bus Width
256-bit
Required Power Supply
500 W
Additional Requirements
8 pin PCI Express power connector
180 Watt
4 cm
26.9 cm
11.1 cm
1.1 kg
