MSI GeForce GTX 1080 ARMOR OC 8GB GDDR5X FROZR Graphics Card
Quicklinx: C5GRWS00 Mfr#: GTX 1080 ARMOR 8G OC
GeForce® GTX 1080 ARMOR 8G OC
Core/Memory
Boost Clock / Base Clock: 1797 MHz / 1657 MHz
8192 MB GDDR5X / 10010 MHz Memory
Video Output Function
DisplayPort x 3
HDMI x 1
Dual-link DVI-D x 1
Virtual Reality Ready
DirectX 12 Ready
Great for 4K
Gamestream to NVIDIA SHIELD
THE ULTIMATE PC GAMING PLATFORM
Get Game Ready with GeForce® GTX.
GeForce GTX graphics cards are the most advanced ever created. Discover unprecedented performance, power efficiency, and next-generation gaming experiences.
THE ULTIMATE GRAPHICS FOR VIRTUAL REALITY
NVIDIA’s unique set of features ensure you get the right level of performance, image quality, and latency to ensure your VR experience is nothing short of amazing
A BETTER GAMING EXPERIENCE
The easiest way to update your drivers, optimize your games, and share your victories
STUTTER, TEAR-FREE GAMEPLAY
Synchronizes the display refresh to your GeForce GTX GPU for the fast, smooth gaming
  • Dual fan
    ARMOR's thermal design is equipped with two fans. Thanks to the blade design, the fans provide strong cooling performance while remaining incredibly silent.
  • Stay undetected
    MSI's special technology eliminates fan noise by stopping the fans in low-load situations. This means you can focus on gaming without the noise of spinning fans.
  • Airflow control
    Under the classy shroud and powerful dual fans is a huge heatsink with countless aluminum fins that help dissipate the heat from the GPU. The copper heat pipes are infused in the baseplate to ensure efficient cooling.
MSI GTX 1080 ARMOR 8G OC - graphics card - GF GTX 1080 - 8 GB - black, white
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1080
8 GB GDDR5X
Core Clock
1657 MHz
Boost Clock
1797 MHz
Effective Memory Clock
10.01 GHz
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
DVI-D (dual link) , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
3.7 cm x 27.9 cm x 14 cm
Enclosure Colour
Black, white
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1657 MHz
Boost Clock
1797 MHz
VR Ready
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
Nvidia 2-way SLI ready, NVIDIA G-Sync ready, Torx Fans, Armor 2X Thermal Design, MSI Zero Frozr technology, Nvidia SHIELD ready, Nvidia GeForce GTX VR Ready, HDCP
Size
8 GB
GDDR5X SDRAM
Effective Clock Speed
10.01 GHz
Bus Width
256-bit
Required Power Supply
500 W
Additional Requirements
6 pin PCI Express power connector, 8 pin PCI Express power connector
180 Watt
Software Included
MSI Afterburner
3.7 cm
27.9 cm
14 cm
877 g
Enclosure Colour
Black, white
Limited warranty - parts and labour - 3 years
