MSI GeForce® GTX 1070 SEA HAWK X
Core/Memory
Boost Clock / Base Clock
1797 MHz / 1607 MHz (OC Mode)
1771 MHz / 1582 MHz (Gaming Mode)
1683 MHz / 1506 MHz (Silent Mode)
8192 MB GDDR5 / 8108 MHz Memory
Video Output Function
DisplayPort x 3
HDMI x 1
Dual-link DVI-D x 1
Virtual Reality Ready
DirectX 12 Ready
Great for 4K
Gamestream to NVIDIA SHIELD
THE ULTIMATE PC GAMING PLATFORM
Get Game Ready with GeForce® GTX.
GeForce GTX graphics cards are the most advanced ever created. Discover unprecedented performance, power efficiency, and next-generation gaming experiences.
THE ULTIMATE GRAPHICS FOR VIRTUAL REALITY
NVIDIA’s unique set of features ensure you get the right level of performance, image quality, and latency to ensure your VR experience is nothing short of amazing
A BETTER GAMING EXPERIENCE
The easiest way to update your drivers, optimize your games, and share your victories
STUTTER, TEAR-FREE GAMEPLAY
Synchronizes the display refresh to your GeForce GTX GPU for the fast, smooth gaming
Supreme liquid cooling performance
Liquid cooling for the GPU and air cooling for the memory and VRMs. -
Micro-fin copper base
Efficient heat transfer to the high-speed circulation pump. -
Silent 120 mm fan
Wide diameter fan with variable speeds based on GPU temperature ensures silent operation. -
Aluminum heat radiator
Low-profile, easy to install black aluminum radiator reduces airflow demand and looks great. -
Easy to install
Closed-loop cooling solution that requires no additional maintenance or assembly. -
Catching the vibe with cool led effects
Featuring a premium LED illuminated MSI logo which can be controlled with the exclusive MSI Gaming App to lighten the mood. -
Backplate
A powerful graphics card needs a strong build to harness its performance. MSI SEA HAWK graphics cards are fitted with a solid metal backplate to make it extra tough. The matte black finish fits perfectly with its sleek design. -
Prepare for VR with MSI
To experience and enjoy the impressive world of Virtual Reality, high-performance hardware is required. MSI, world leading brand in high-end gaming and eSports, provides the right advice to make sure your system is VR Ready. Integrating the very best of cutting edge technologies in recommended MSI VR gaming hardware for smooth performance.
- MSI GTX 1070 SEA HAWK X - graphics card - GF GTX 1070 - 8 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1070
- Memory
- 8 GB GDDR5
- Core Clock
- 1607 MHz
- Boost Clock
- 1797 MHz
- Effective Memory Clock
- 8.108 GHz
- Memory Interface
- 256-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-D (dual link) , 3 x DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- 4 cm x 27 cm x 11.1 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1607 MHz
- Boost Clock
- 1797 MHz
- VR Ready
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- Nvidia 2-way SLI ready, NVIDIA G-Sync ready, 120 mm external watercool kit radiator, micro-fin copper base, Nvidia GeForce GTX VR Ready, HDCP
- Size
- 8 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 8.108 GHz
- Bus Width
- 256-bit
- Required Power Supply
- 500 W
- 150 Watt
- Included Accessories
- Backplate, liquid-cooling module
- Software Included
- MSI Afterburner, MSI Gaming App
- 4 cm
- 27 cm
- 11.1 cm
- 1.249 kg
