GeForce® GTX 1070 GAMING X 8G
Core/Memory
Boost Clock / Base Clock:
1797 MHz / 1607 MHz (OC Mode)
1771 MHz / 1582 MHz (Gaming Mode)
1683 MHz / 1506 MHz (Silent Mode)
8192 MB GDDR5 / 8108 MHz Memory (OC Mode)
Video Output Function
DisplayPort x 3
HDMI x 1
Dual-link DVI-D x 1
Virtual Reality Ready
DirectX 12 Ready
Great for 4K
Gamestream to NVIDIA SHIELD
THE ULTIMATE PC GAMING PLATFORM
Get Game Ready with GeForce® GTX.
GeForce GTX graphics cards are the most advanced ever created. Discover unprecedented performance, power efficiency, and next-generation gaming experiences.
THE ULTIMATE GRAPHICS FOR VIRTUAL REALITY
NVIDIA’s unique set of features ensure you get the right level of performance, image quality, and latency to ensure your VR experience is nothing short of amazing
A BETTER GAMING EXPERIENCE
The easiest way to update your drivers, optimize your games, and share your victories
STUTTER, TEAR-FREE GAMEPLAY
Synchronizes the display refresh to your GeForce GTX GPU for the fast, smooth gaming
TORX 2.0 FAN
Teamwork for greater strength
Just like in games, the exclusive MSI TORX 2.0 Fan technology uses the power of teamwork to allow the TWIN FROZR VI to achieve new levels of cool.
TORX 2.0 Fan design generates 22% more air pressure for supremely silent performance in the heat of battle.
Zero Frozr-Stay undetected
First introduced in 2008 by MSI, ZeroFrozr technology has made its mark and is now the industry standard among graphics cards. It eliminates fan noise by stopping the fans in low-load situations. This means you can focus on gaming without the noise of spinning fans.
Catch the Vibe with Cool LED Effects
Each LED can be controlled individually by choosing any of the animation effects availiable in the MSI Gaming App, ranging from responding to your game sounds or music to steady light, breathing and flashing. Of course, you can also turn them off.
HEATSINK
Lurking under the cover of the GAMING graphics card is an engineering masterpiece designed to keep the graphics card cool. Every tiny detail of the intricate heatsink plays an essential part in providing a cool & quiet gaming experience.
Airflow Control Technology
Using advanced aerodynamics, Airflow Control Technology directs more air directly onto the TWIN FROZR VI heat pipes. The special deflectors on the heat sink enlarge the surface area, which means lower temperatures and better gaming.
Multi GPU
Gaming enthusiasts are always looking for more performance to get the ultimate experience. Using multiple graphics cards in SLI or Crossfire is a great way to find out just how good it gets. MSI GAMING graphics cards fully support multi GPU technologies.
PREPARE FOR VR with MSI
To experience and enjoy the impressive world of Virtual Reality, high-performance hardware is required. MSI, world leading brand in high-end gaming and eSports, provides the right advice to make sure your system is VR Ready. Integrating the very best of cutting edge technologies in recommended MSI VR gaming hardware for smooth performance. Together with our VR partners, MSI brings gamers an extremely realistic VR experience where games come alive.
Torx 2.0 fan technology
Torx 2.0 fan design generates more air pressure for supremely silent performance in the heat of battle. -
Catch the vibe with cool LED effects
Each LED can be controlled individually by choosing the animation effects, ranging from responding to your game sounds or music to steady light, breathing and flashing. Of course, you can also turn them off. -
Airflow Control technology
Using advanced aerodynamics, Airflow Control technology directs more air directly onto the Twin Frozr VI heat pipes. The special deflectors on the heat sink enlarge the surface area, which means lower temperatures and better gaming. -
Smooth heat pipes
Thick copper heat pipes with a smooth squared shape at the bottom maximize heat transfer from the surface of the copper base plate. -
Solid baseplate
To temper the heat generated by a powerful GPU, MSI GAMING series graphics cards use a solid nickel-plated copper base plate. The base plate catches the heat from the GPU and transfers it to the heat pipes for dissipation so you can keep cool. -
Multi GPU technologies
Gaming enthusiasts are always looking for more performance to get the ultimate experience. Using multiple graphics cards is a great way to find out just how good it gets. MSI GAMING graphics cards fully support multi GPU technologies.
- MSI GTX 1070 GAMING X 8G - graphics card - GF GTX 1070 - 8 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1070
- Memory
- 8 GB GDDR5
- Core Clock
- 1607 MHz
- Boost Clock
- 1797 MHz
- Effective Memory Clock
- 8.108 GHz
- Memory Interface
- 256-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-D (dual link) , 3 x DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- 4.2 cm x 27.9 cm x 14 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1607 MHz
- Boost Clock
- 1797 MHz
- VR Ready
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- Nvidia SLI Multi-GPU Technology, Nvidia 2-way SLI ready, Dual Fan Design, MSI Afterburner, Twin Frozr IV Thermal Design, MSI Gaming App, Airflow Control technology, NVIDIA G-Sync ready, Torx Fans, MSI Zero Frozr technology, Nvidia SHIELD ready, Nvidia GeForce GTX VR Ready, HDCP
- Size
- 8 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 8.108 GHz
- Bus Width
- 256-bit
- Required Power Supply
- 500 W
- Additional Requirements
- 6 pin PCI Express power connector, 8 pin PCI Express power connector
- 150 Watt
- Software Included
- MSI Afterburner, MSI Gaming App, XSplit Gamecaster 2 (1 year Premium licence)
- 4.2 cm
- 27.9 cm
- 14 cm
- 1.1 kg
- Limited warranty - parts and labour - 3 years
