MSI GeForce GTX 1070 AERO 8G OC
THE ULTIMATE PC GAMING PLATFORM
Get Game Ready with GeForce® GTX.
GeForce GTX graphics cards are the most advanced ever created. Discover unprecedented performance, power efficiency, and next-generation gaming experiences.
THE ULTIMATE GRAPHICS FOR VIRTUAL REALITY
NVIDIA’s unique set of features ensure you get the right level of performance, image quality, and latency to ensure your VR experience is nothing short of amazing
A BETTER GAMING EXPERIENCE
The easiest way to update your drivers, optimize your games, and share your victories
STUTTER, TEAR-FREE GAMEPLAY
Synchronizes the display refresh to your GeForce GTX GPU for the fast, smooth gaming
Core/Memory
Boost Clock / Base Clock
721 MHz / 1531 MHz
8192 MB GDDR5 / 8008 MHz Memory
Video Output Function
DisplayPort x 3
HDMI x 1
Dual-link DVI-D x 1
Virtual Reality Ready
DirectX 12 Ready
Great for 4K
Gamestream to NVIDIA SHIELD
Amazing design
MSI AERO graphics cards are equipped with a great design, crafted from high-quality materials. The sleek looks will fit great in almost any build. -
The great graphics for virtual reality
NVIDIA's set of features ensure you get the right level of performance, image quality, and latency to ensure your VR experience is nothing short of amazing. -
Stutter, tear-free gameplay
Synchronizes the display refresh to your GeForce GTX GPU for the fast, smooth gaming. -
High-quality components
These components are durable enough to withstand the torturous circumstances of extreme gaming and overclocking for extended usage. -
Prepare for VR with MSI
To experience and enjoy the impressive world of virtual reality, high-performance hardware is required. MSI provides the right advice to make sure your system is VR ready. MSI brings gamers an extremely realistic VR experience where games come alive. -
MSI Afterburner
MSI Afterburner is the widely used graphics card overclocking utility which gives you full control of your graphics cards. It also provides an incredibly detailed overview of your hardware and comes with some additional features such as customizing fan profiles, benchmarking and video recording.
- MSI GTX 1070 AERO 8G OC - graphics card - GF GTX 1070 - 8 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1070
- Memory
- 8 GB GDDR5
- Core Clock
- 1531 MHz
- Boost Clock
- 1721 MHz
- Effective Memory Clock
- 8.008 GHz
- Memory Interface
- 256-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-D (dual link) , 3 x DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- 3.5 cm x 26.9 cm x 11.1 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1531 MHz
- Boost Clock
- 1721 MHz
- VR Ready
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- Nvidia SLI Multi-GPU Technology, MSI Solid Capacitor, Nvidia 2-way SLI ready, MSI Afterburner, Military Class 4 Components, NVIDIA G-Sync ready, Nvidia SHIELD ready, Nvidia GeForce GTX VR Ready, HDCP
- Size
- 8 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 8.008 GHz
- Bus Width
- 256-bit
- Required Power Supply
- 500 W
- Additional Requirements
- 8 pin PCI Express power connector
- 150 Watt
- Software Included
- MSI Afterburner
- MIL-STD 810G
- 3.5 cm
- 26.9 cm
- 11.1 cm
- 840 g
- Limited warranty - parts and labour - 3 years
