MSI GeForce GTX 1060 GAMING X 6G 6GB GDDR5 TWIN FROZR VI
Quicklinx: C7ZDWS00 Mfr#: GTX 1060 GAMING X 6G
GEFORCE GTX 1060
10: Gaming Perfected
The GeForce GTX 1060 graphics card is loaded with innovative new gaming technologies, making it the perfect choice for the latest high-definition games. Powered by NVIDIA Pascal™—the most advanced GPU architecture ever created—the GeForce GTX 1060 delivers brilliant performance that opens the door to virtual reality and beyond. #GameReady.
NVIDIA PASCAL
THE WORLD'S MOST ADVANCED GPU ARCHITECTURE
GeForce GTX 10-series graphics cards are powered by Pascal to deliver up to 3x the performance of previous-generation graphics cards, plus innovative new gaming technologies and breakthrough VR experiences.
  • Ultimate PC gaming platform
    Get game ready with GeForce GTX. GeForce GTX graphics cards are extremely advanced. Discover unprecedented performance, power efficiency, and outstanding gaming experiences.
  • VR ready
    Discover next-generation VR performance, low latency, and Plug-and-Play compatibility with leading headsets - driven by NVIDIA VRWorks technologies. VR audio, physics, and haptics let you hear and feel every moment.
  • Advanced gaming technologies
    Pascal is built to meet the demands of next generation displays, including VR, ultra-high-resolution, and multiple monitors. It features NVIDIA GameWorks technologies for extremely smooth gameplay and cinematic experiences. Plus, it includes revolutionary 360-degree image capture.
  • Teamwork for greater strength
    Just like in games, the MSI Torx 2.0 Fan technology uses the power of teamwork to allow the Twin Frozr VI to achieve new levels of cool.
  • Heatsink
    Lurking under the cover of the gaming graphics card is an engineering masterpiece designed to keep the graphics card cool. Every tiny detail of the intricate heatsink plays an essential part in providing a cool and quiet gaming experience.
  • Airflow Control technology
    Using advanced aerodynamics, Airflow Control technology directs more air directly onto the Twin Frozr VI heat pipes. The special deflectors on the heat sink enlarge the surface area, which means lower temperatures and better gaming.
  • Smooth heat pipes
    Up to 8 mm thick copper heat pipes with a smooth squared shape at the bottom maximize heat transfer from the surface of the copper base plate.
  • Solid base plate
    To temper the heat generated by a powerful GPU, MSI Gaming series graphics cards use a solid nickel-plated copper base plate. The base plate catches the heat from the GPU and transfers it to the heat pipes for dissipation so you can keep cool.
  • Premium thermal compound
    Every detail counts when it comes to creating the ultimate thermal design, which is why Twin Frozr VI uses a premium thermal compound to make sure it outlives the competition.
  • Backplate
    A powerful graphics card needs a strong build to harness its performance. MSI Gaming X graphics cards are fitted with a solid metal back plate to make it extra tough. The matte dark finish completes the Twin Frozr VI design to perfection.
MSI GTX 1060 GAMING X 6G - graphics card - GF GTX 1060 - 6 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1060
6 GB GDDR5
Core Clock
1594 MHz
Boost Clock
1809 MHz
Effective Memory Clock
8.1 GHz
Memory Interface
192-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
DVI-D (dual link) , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
3.9 cm x 27.7 cm x 14 cm
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1594 MHz
Boost Clock
1809 MHz
VR Ready
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
MSI Solid Capacitor, Dual Fan Design, MSI Afterburner, 6 Phase PWM Design, MSI Gaming App, Military Class 4 Components, Hi-C CAP, Super Ferrite Chokes, Airflow Control technology, NVIDIA G-Sync ready, MSI Zero Frozr technology, LED illuminated MSI Gaming Dragon, Nvidia SHIELD ready, Nvidia GeForce GTX VR Ready, Torx 2.0 Fans, Twin Frozr VI Thermal Design, HDCP
Size
6 GB
GDDR5 SDRAM
Effective Clock Speed
8.1 GHz
Bus Width
192-bit
Required Power Supply
400 W
Additional Requirements
8 pin PCI Express power connector
120 Watt
Software Included
MSI Afterburner, MSI Gaming App, XSplit Gamecaster 2 (1 year Premium licence)
3.9 cm
27.7 cm
14 cm
1.017 kg
Limited warranty - parts and labour - 3 years
