MSI GeForce GTX 1060 ARMOR 6G OC 6GB GDDR5 TORX Fan GraphicsCard
Quicklinx: C7ZBWS00 Mfr#: GTX 1060 ARMOR 6G OC
GEFORCE GTX 1060
10: Gaming Perfected
The GeForce GTX 1060 graphics card is loaded with innovative new gaming technologies, making it the perfect choice for the latest high-definition games. Powered by NVIDIA Pascal™—the most advanced GPU architecture ever created—the GeForce GTX 1060 delivers brilliant performance that opens the door to virtual reality and beyond. #GameReady.
NVIDIA PASCAL
THE WORLD'S MOST ADVANCED GPU ARCHITECTURE
GeForce GTX 10-series graphics cards are powered by Pascal to deliver up to 3x the performance of previous-generation graphics cards, plus innovative new gaming technologies and breakthrough VR experiences.
  • Dual fan
    ARMOR 2X thermal design is equipped with two of the Torx fans. Thanks to the blade design, MSI Torx fans provide strong cooling performance while remaining incredibly silent.
  • Heatsink and Airflow Control
    Under the classy shroud and powerful dual fans is a huge heatsink with countless aluminum fins, that help dissipate the heat from the GPU. The copper heatpipes are infused in the baseplate to ensure efficient cooling. The aluminum fins are rigged with Airflow Control technology to maximize airflow towards the heatpipes.
  • Prepare for VR with MSI
    To experience and enjoy the impressive world of virtual reality, high-performance hardware is required. MSI provides the right advice to make sure your system is VR ready. Integrating the optimal of advanced technologies in recommended MSI VR gaming hardware for smooth performance. Together with the VR partners, MSI brings gamers an extremely realistic VR experience, where games come alive.
MSI GTX 1060 ARMOR 6G OC - graphics card - GF GTX 1060 - 6 GB - black, white
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1060
6 GB GDDR5
Core Clock
1544 MHz
Boost Clock
1759 MHz
Effective Memory Clock
8 GHz
Memory Interface
192-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
DVI-D (dual link) , 3 x DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
3.8 cm x 27.9 cm x 14 cm
Enclosure Colour
Black, white
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1544 MHz
Boost Clock
1759 MHz
VR Ready
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
Nvidia 2-way SLI ready, MSI Afterburner, 6 Phase PWM Design, Hi-C CAP, Super Ferrite Chokes, Airflow Control technology, NVIDIA G-Sync ready, NVIDIA GameWorks, Torx Fans, Armor 2X Thermal Design, MSI Zero Frozr technology, Nvidia SHIELD ready, Nvidia GeForce GTX VR Ready, HDCP
Size
6 GB
GDDR5 SDRAM
Effective Clock Speed
8 GHz
Bus Width
192-bit
Required Power Supply
400 W
Additional Requirements
8 pin PCI Express power connector
120 Watt
3.8 cm
27.9 cm
14 cm
737 g
Enclosure Colour
Black, white
