MSI GeForce GTX 1060 6GT OC 6GB GDDR5 PCIe3.0 Graphics Card
Quicklinx: C7Z9WS00 Mfr#: GTX 1060 6GT OC
GEFORCE GTX 1060
10: Gaming Perfected
The GeForce GTX 1060 graphics card is loaded with innovative new gaming technologies, making it the perfect choice for the latest high-definition games. Powered by NVIDIA Pascal™—the most advanced GPU architecture ever created—the GeForce GTX 1060 delivers brilliant performance that opens the door to virtual reality and beyond. #GameReady.
NVIDIA PASCAL
THE WORLD'S MOST ADVANCED GPU ARCHITECTURE
GeForce GTX 10-series graphics cards are powered by Pascal to deliver up to 3x the performance of previous-generation graphics cards, plus innovative new gaming technologies and breakthrough VR experiences.
  • Dual fans thermal design
    Dual fans covers more area of heatsink to take heat away more efficiently.
  • Military class 4 components
    One of the deciding factors in performance is the quality of the components used. That is why MSI only uses MIL-STD-810G certified components. Only these components have proven durable enough to withstand the torturous circumstances of extreme gaming and overclocking for extended usage.
  • The future of gaming
    The smoothest, fastest and most exciting gaming experience ever by eliminating screen tearing, display shutter and input lag.
  • Prepare for VR with MSI
    To experience and enjoy the impressive world of Virtual Reality, high-performance hardware is required. MSI, world leading brand in high-end gaming and eSports, provides the right advice to make sure your system is VR Ready. Integrating the very best of cutting edge technologies in recommended MSI VR gaming hardware for smooth performance.
  • MSI Afterburner
    MSI Afterburner is one of the world's most recognized and widely used graphics card overclocking utility which gives you full control of your graphics cards. It also provides an incredibly detailed overview of your hardware and comes with some additional features such as customizing fan profiles, benchmarking and video recording.
MSI GTX 1060 6GT OC - graphics card - GF GTX 1060 - 6 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1060
6 GB GDDR5
Core Clock
1544 MHz
Boost Clock
1759 MHz
Effective Memory Clock
8 GHz
Memory Interface
192-bit
Max Monitors Supported
3
Interfaces Details
DVI-D (dual link) , DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
3.9 cm x 24.7 cm x 11.5 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1544 MHz
Boost Clock
1759 MHz
VR Ready
3
Interfaces Details
API Supported
MSI Solid Capacitor, Dual Fan Design, MSI Afterburner, Military Class 4 Components, Hi-C CAP, NVIDIA G-Sync ready, NVIDIA GameWorks, Nvidia GeForce GTX VR Ready, HDCP
Size
6 GB
GDDR5 SDRAM
Effective Clock Speed
8 GHz
Bus Width
192-bit
Required Power Supply
400 W
Additional Requirements
6 pin PCI Express power connector
120 Watt
MIL-STD 810G
3.9 cm
24.7 cm
11.5 cm
591 g
