MSI GeForce GTX 1050 GAMING X 2GB GDDR5 PCIe3.0 Graphics Card
Quicklinx: CGHQWS00 Mfr#: GTX1050-GAMING-X-2G
Graphics Processor Manufacturer: NVIDIA
Graphics Processor: NVIDIA GeForce GTX 1050, NVIDIA GeForce GTX 1050, NVIDIA GeForce GTX 1050
Interface: PCI Express 3.0 x16
Memory Size: 2GB, 2GB
Digital Output: DisplayPort, Dual DVI, High-Definition Multimedia Interface (HDMI)
  • High-Definition Multimedia Interface (HDMI)
  • DisplayPort
Hurry, only 1 left in stock!
£115.61 ex VAT
£138.73 inc VAT
TWIN FROZR VI
- The Ultimate Thermal Design
The new TWIN FROZR VI Thermal Design raises the bar of Graphics Card air cooling. It's 40% more silent compared to the award winning TWIN FROZR V. Details make all the difference.
Twin Frozr logo
GTX 1050 GAMING X 8G exploded view
  • Dynamic LED
  • Military Class Components
  • Tailored PCB Design
  • Heatsink
  • TORX 2.0 Fan
  • Zero Frozr
GAMING X logo
TWIN FROZR VI: Cool, Silent & Stable Performance
Perfectly balanced with excellent cooling for stable gaming performance while staying incredibly silent during intense gaming.
Cool
Cooling graph
Max. temp (10 mins of FireStrike)
Silent
Noise graph
Noise under load
Stable performance
Performance graph Stable performance Unstable performance
Torx Fan 2.0 logo
TORX 2.0 FAN - Teamwork for greater strength
The exclusive MSI TORX 2.0 Fan technology uses the power of teamwork to allow the TWIN FROZR VI to achieve new levels of cool.
TORX 2.0 Fan design generates 22% more air fan pressure for supremely silent performance in the heat of battle.
 Dispersion fan airflow
Dispersion fan blade
Traditional fan blade
ZERO FROZR - Stay Undetected
First introduced in 2008 by MSI, Zero Frozr technology has made its mark and is now the industry standard among graphics cards. It eliminates fan noise by stopping the fans in low-load situations. This means you can focus on gaming without the noise of spinning fans.
Zero Frozr
> 60°C: Fans spinning
During intense gaming or benchmarking
60 Fans stop
Completely silent during idle, multimedia or light gaming
Catch the vibe with cool LED effects
Each LED can be controlled individually by choosing any of the animation effects available in the MSI Gaming App, ranging from responding to your game sounds or music to steady light, breathing and flashing. Of course, you can also turn them off.
Led effects MSI Gaming App
Software
Supports
Nvidia G-Sync logo
  • TORX 2.0 fan
    Just like in games, the exclusive MSI TORX 2.0 Fan technology uses the power of teamwork to allow the TWIN FROZR VI to achieve new levels of cool. TORX 2.0 Fan design generates 22% more air pressure for supremely silent performance in the heat of battle.
  • Airflow control technology
    Using advanced aerodynamics, Airflow Control Technology directs more air directly onto the TWIN FROZR VI heat pipes. The special deflectors on the heat sink enlarge the surface area, which means lower temperatures and better gaming.
  • The future of gaming
    The smooth, fast and most exciting gaming experience ever by eliminating screen tearing, display shutter and input lag. Ultra-high resolution (UHD) delivers 4x the resolution of 1080p content, enabling much sharper and crisper images with delicate details during gaming.
MSI GTX 1050 GAMING X 2G - graphics card - NVIDIA GeForce GTX 1050 - 2 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
2 GB GDDR5
Core Clock
1442 MHz
Boost Clock
1556 MHz
Effective Memory Clock
7.108 GHz
Memory Interface
128-bit
Max Resolution
2560 x 1600
Max Monitors Supported
3
DVI-D (dual link) , DisplayPort , HDMI
API Supported
DirectX 12, OpenGL 4.5
3.9 cm x 22.9 cm x 13.1 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1442 MHz
Boost Clock
1556 MHz
Max Resolution
2560 x 1600
3
API Supported
MSI Afterburner, NVIDIA G-Sync ready, NVIDIA GameWorks, MSI Zero Frozr technology, Torx 2.0 Fans, Twin Frozr VI Thermal Design, FinFET technology, HDCP
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
7.108 GHz
Bus Width
128-bit
Required Power Supply
300 W
Additional Requirements
6 pin PCI Express power connector
75 Watt
3.9 cm
22.9 cm
13.1 cm
527 g
Memory Size: 2GB
Memory Size: 2GB
Digital Output: Dual DVI
Digital Output: High-Definition Multimedia Interface (HDMI)
Brand: MSI
Price Range Ex VAT: 100 - 150
