TORX 2.0 fan
Just like in games, the exclusive MSI TORX 2.0 Fan technology uses the power of teamwork to allow the TWIN FROZR VI to achieve new levels of cool. TORX 2.0 Fan design generates 22% more air pressure for supremely silent performance in the heat of battle. -
Airflow control technology
Using advanced aerodynamics, Airflow Control Technology directs more air directly onto the TWIN FROZR VI heat pipes. The special deflectors on the heat sink enlarge the surface area, which means lower temperatures and better gaming. -
The future of gaming
The smooth, fast and most exciting gaming experience ever by eliminating screen tearing, display shutter and input lag. Ultra-high resolution (UHD) delivers 4x the resolution of 1080p content, enabling much sharper and crisper images with delicate details during gaming.
- MSI GTX 1050 GAMING X 2G - graphics card - NVIDIA GeForce GTX 1050 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- Memory
- 2 GB GDDR5
- Core Clock
- 1442 MHz
- Boost Clock
- 1556 MHz
- Effective Memory Clock
- 7.108 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 2560 x 1600
- Max Monitors Supported
- 3
- Interfaces Details
- DVI-D (dual link) , DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- 3.9 cm x 22.9 cm x 13.1 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1442 MHz
- Boost Clock
- 1556 MHz
- Max Resolution
- 2560 x 1600
- 3
- API Supported
- MSI Afterburner, NVIDIA G-Sync ready, NVIDIA GameWorks, MSI Zero Frozr technology, Torx 2.0 Fans, Twin Frozr VI Thermal Design, FinFET technology, HDCP
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 7.108 GHz
- Bus Width
- 128-bit
- Required Power Supply
- 300 W
- Additional Requirements
- 6 pin PCI Express power connector
- 75 Watt
- 3.9 cm
- 22.9 cm
- 13.1 cm
- 527 g
