MSI GeForce GTX  960 GAMING 4GB GDDR5 PCI-E ATX
Quicklinx: B5DSWS00 Mfr#: GTX 960 GAMING 4G
  • NVIDIA GeForce GTX 960
With every generation of GPUs comes more performance. Twin Frozr V is smaller, features stronger fans, generates less noise, keeps your graphics card and its components cooler and matches perfectly with your MSI Gaming motherboard including some funky LED lightning.
MSI has fitted Twin Frozr coolers with the Airflow Control technology which guides more airflow directly onto the heat pipes by using special deflectors on the heat sink. In addition, this exclusive heat sink design increases heat sink surface area, greatly enhancing the dissipation efficiency.
  • Twin Frozr V - cooler, quieter, better gaming
  • Enhanced dissipation efficiency
    SuperSU Architecture is the best cooling solution for graphics cards. The GPU is cooled by a massive nickel-plated copper base plate connected to Super Pipes (8mm heat pipes) on the MSI Gaming series graphics card. Additionally, the heat pipe layout increases efficiency by reducing the length of unused heat pipe and a special SU-form design.
  • Smart cooling, stay quiet
    MSI's Twin Frozr V Thermal designs are equipped with Zero Frozr technology which was first introduced by MSI back in 2008. Zero Frozr technology eliminates fan noise in low-load situations by stopping the fans when they are not needed. Compared to other graphics cards, there is no continuous hum of airflow to tell you there's a powerful graphics card in your gaming rig. This means you can focus on gaming without the distraction of other sounds coming from your PC.
  • Catching the Vibe with Cool LED effects
    Featuring a premium LED illuminated MSI GAMING Dragon to lighten the mood. This function allows you to choose from 5 unique modes to set the right ambience for your gaming moments with just one click.
  • More performance
    MSI Gaming Graphics Cards give you more performance out of the box. Whether you use the card pre-overclocked or use the Gaming App to use its full potential, you can just get right into the game and enjoy sublime performance. Overclocking through the MSI Gaming App is covered by warranty to take away your worries. Get in there and start winning!
  • Afterburner
    MSI Afterburner is world's favorite cross-vendor GPU overclocking tool. The easy interface gives access to the most detailed information about your graphics card and allows for tinkering with pretty much anything available on your graphics card.
  • Predator
    A built-in screen and video capturing tool named Predator which captures your screen as still images or videos with the push of a button and allows you to capture and record your coolest, goofiest and most awesome gaming moments on your PC!
MSI GTX 960 Gaming 4G - graphics card - GF GTX 960 - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
4 GB GDDR5
Core Clock
1241 MHz
Boost Clock
1304 MHz
Effective Memory Clock
7.01 GHz
RAMDAC
400 MHz
Memory Interface
128-bit
Max Resolution
4096 x 2160
Max Resolution Details
DVI: 2560 x 1600 at 60 Hz / DisplayPort: 4096 x 2160 at 60 Hz / HDMI: 4096 x 2160 at 24 Hz; 3840 x 2160 at 60 Hz
Max Monitors Supported
4
Interfaces Details
DVI-I (dual link) , 3 x DisplayPort , HDMI , VGA - with adapter
API Supported
OpenGL 4.4, DirectX 12
4 cm x 26.7 cm x 13.9 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1241 MHz
Boost Clock
1304 MHz
RAMDAC
400 MHz
Max Resolution
4
Interfaces Details
API Supported
MSI SuperPipe Technology, MSI Solid Capacitor, Nvidia 3D Vision technology, Nvidia 2-way SLI ready, Nvidia Surround technology, MSI Afterburner, NVIDIA GPU Boost 2.0, MSI Gaming App, Military Class 4 Components, Hi-C CAP, Super Ferrite Chokes, Airflow Control technology, Twin Frozr V Thermal Design, Torx Fans, SuperSU Architecture, MSI Zero Frozr technology, LED illuminated MSI Gaming Dragon, HDCP
Size
4 GB
GDDR5 SDRAM
Effective Clock Speed
7.01 GHz
Bus Width
128-bit
Required Power Supply
400 W
Additional Requirements
8 pin PCI Express power connector
120 watt
8 pin power cable
1 x DVI-VGA adapter
Software Included
MSI Afterburner, MSI Predator
MIL-STD 810G
4 cm
26.7 cm
13.9 cm
833 g
