MSI GeForce GT 710 2GB DDR3 Dual-DVI-D HDMI Graphics Card
Quicklinx: BWGBWS00 Mfr#: GT 710 2GD3H LP
Graphics Processor Manufacturer: NVIDIA
Graphics Processor: NVIDIA GeForce GT 710, NVIDIA GeForce GT 710, NVIDIA GeForce GT 710
Interface: PCI Express 2.0 x16
Memory Size: 2GB, 2GB
More than 50 in stock
£40.39 ex VAT
£48.46 inc VAT
Core/Memory
• 954 MHz Core
• 2048MB DDR3 1600 MHz
Video Output Function
• Dual-link DVI-D x 1
• HDMI x 1 (Version 1.4a)
• D-Sub x 1
All Solid Capacitors
10 years ultra-long lifetime (under full load).
Lower temperature and higher efficiency.
Extreme low ESR.
Noise Free
Large heat sink covers the area of GPU and memory.
Providing the best environment for gaming and multimedia.
Low Profile Design
Low profile design saves more spaces.
User can build slim or smaller system easier.
Afterburner Overclocking Utility
Support in-game video recording.
Support wireless control by android/iOS handheld devices.
Support built-in DX12 effect test.
MSI GT 710 2GD3H LP - graphics card - GF GT 710 - 2 GB
Graphics card - low profile
Bus Type
PCI Express 2.0 x16
Graphics Engine
2 GB DDR3
Core Clock
954 MHz
Effective Memory Clock
1.6 GHz
RAMDAC
400 MHz
Memory Interface
64-bit
Max Resolution
4096 x 2160
Max Monitors Supported
2
DVI-D (dual link) , HDMI , VGA
API Supported
DirectX 12, OpenGL 4.5
1.9 cm x 14.6 cm x 6.9 cm
Bus Type
PCI Express 2.0 x16
Graphics Engine
Core Clock
954 MHz
RAMDAC
400 MHz
Max Resolution
4096 x 2160 at 24 Hz
2
API Supported
MSI Solid Capacitor, fanless heatsink, MSI Afterburner, HDCP
Size
2 GB
DDR3 SDRAM
Effective Clock Speed
1.6 GHz
Bus Width
64-bit
Required Power Supply
300 W
19 Watt
Software Included
Adobe Acrobat Reader, MSI Live Update Series, Microsoft DirectX, MSI Afterburner, display drivers, Norton Internet Security (60 days trial)
1.9 cm
14.6 cm
6.9 cm
178 g
Memory Size: 2GB
Memory Size: 2GB
Brand: MSI
Price Range Ex VAT: 0 - 50
