This advanced notebook by MSI features the special MSI SHIFT technology, which pushes system to the extreme while minimizing noise and temperature. Switch between three profiles Sport, Comfort, and Green to reach balance between system performance and comfortable user experience. Get the best possible performance out of your notebook with support of the advanced DDR4-2133 memory, achieving amazingly high reading and writing speeds. MSI True Color technology ensures that each panel in a MSI notebook comes with amazing precision in color. Hence, each color is delivered with precision in detail for excellent color fidelity. And wide-viewing angle display allows you to experience better image quality with vivid colors and consistent brightness levels whether you're looking at the screen from above, below, the front or the side.
Load games in seconds
Get in the game before everyone else with PCI-E Gen 3.0 utilizing NVMe technology. Harness the full performance potential of the Gen 3.0, ensuring extreme read and write speeds. -
Boost performance under controlled noise & temperature
The special MSI SHIFT technology pushes system to the extreme while minimizing noise and temperature. Switch between three profiles Sport, Comfort, and Green to reach balance between system performance and comfortable user experience. -
DDR4-2133 memory support
Get the best possible performance out of your notebook with support of the advanced DDR4-2133 memory, achieving amazingly high reading and writing speeds. -
Keep calm under pressure
MSI advanced Cooler Boost 3 technology creates dual thermal modules internally by allocating dedicated heat pipes for GPU and CPU. One click on the fan boost button, and a total of 9 heat pipes and dual fans will actively and effectively push heat out of the system. -
MSI True Color technology ensures that each panel in a MSI notebook comes with amazing precision in color. Hence, each color is delivered with precision in detail for excellent color fidelity. -
Matrix Display
Expand the vision for extreme gaming experience. The Matrix Display technology supports up to 2 external displays. Multitasking is made possible even during competitive gameplays. -
Wide-viewing angle display
Experience better image quality, the wide-view angle panel boasts enhanced contrast level and brightness, with vivid colors and consistent brightness levels whether you're looking at the screen from above, below, the front or the side. -
Nahimic virtual surround
Designed to work with standard audio and stereo equipment, Nahimic transports gamers into the action, allowing them to sense every footstep, hear every bullet whizzing past, and feel every explosion. It also features a high-definition audio recorder to easily capture and stream studio quality. -
Sound by Dynaudio 2.1 speaker system
GT72 notebook is packing the advanced speakers design with 2 channels with 1 subwoofer, and absolutely authentic hearing experience. The signal has been enhanced and the volume has been increased; people who play games or enjoy movies will absolutely be immersed in the perfect system with outstanding sound effect. -
Audio Boost 2 with 3 independent amps
By utilizing dedicated headset amplifiers, an isolated audio board and gold-plated audio jacks, Audio Boost 2 delivers advanced listening and improves audio performance. Audio Boost 2 provides gamers a more detailed aural picture of their surroundings, helping in-game, while also minimizing distortion and providing a powerful amplifier which has no trouble powering even demanding gaming headsets. Gold-plated jacks will give you less noise interference and ensure the long-term durability of the jack. -
Silver lining print
See more and do more in the night with high-grade silver lining printed keys. See the full color spectrum on the SteelSeries multicolor keyboard and enjoy longer lasting keys worry free of long-term wear and tear. -
Killer Gaming LAN - protecting your ping
In the gaming battlefield, speed defines the winner. Stop losing games to lag with Killer Gaming Lan. The advanced stream detect protects networking traffic and prevents lag spikes through controlling and managing up to 6 priority levels. You can game without fear and play at your best while tracking your speeds with the easy-to-use Killer Networking Manager.
- MSI GE72 6QD 033UK Apache Pro - 17.3" - Intel Core i7 6700HQ - 8 GB RAM - 128 GB SSD + 1 TB HDD
- Product Type
- Notebook
- Operating System
- Windows 10 Home
- Processor
- Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz (3.5 GHz) / 6 MB Cache
- Memory
- 8 GB DDR4
- Storage
- 128 GB SSD + 1 TB HDD / 7200 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 17.3" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA GeForce GTX 960M
- Video Memory
- 2 GB GDDR5 SDRAM
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 6-cell
- 41.99 cm x 28.78 cm x 3.2 cm
- 2.9 kg
- Limited warranty - 2 years
- Product Type
- Notebook
- Operating System
- Windows 10 Home
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Chipset
- Mobile Intel HM170
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
Storage
- Main Storage
- 128 GB SSD SATA 6Gb/s
- Secondary Storage
- 1 TB HDD SATA 6Gb/s / 7200 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
Display
- 17.3"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Anti-glare, WideView, MSI Matrix Display, MSI True Colour Technology
Audio & Video
- Graphics Processor
- Video Memory
- 2 GB GDDR5 SDRAM
- Camera
- Yes - 720p
- Sound
- Stereo speakers, subwoofer, microphone
- Audio Features
- Output: 7.1 SPDIF, Dynaudio Premium Sound Technology, MSI Audio Boost 2, Nahimic sound technology
Input
- Keyboard, touchpad
- SteelSeries Engine 3, SteelSeries Full Color
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Killer Ethernet E2400
- Technology
- 6-cell
AC Adapter
- Output
- 120 Watt
Connections & Expansion
- LAN , Microphone input , Headphone output , 2 x USB 3.0 , HDMI , Mini DisplayPort , USB 2.0 , USB-C
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- SteelSeries Engine 3, XSplit Gamecaster 2 (1 year Premium licence)
- SteelSeries gaming keyboard, Cooler Boost 3 technology, MSI SHIFT Technology
- Included Accessories
- Power adapter
- 2.9 kg
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
