MSI GE72 Intel Skylake i7-6700HQ 8GB 1TB & 128GBSSD 17.3" Windows 10 Home
Quicklinx: BVH4WS00 Mfr#: 9S7-179541-033
  • Core i7
  • Bluetooth 4.0
  • IEEE 802.11n
  • NVIDIA GeForce GTX 960M
This advanced notebook by MSI features the special MSI SHIFT technology, which pushes system to the extreme while minimizing noise and temperature. Switch between three profiles Sport, Comfort, and Green to reach balance between system performance and comfortable user experience. Get the best possible performance out of your notebook with support of the advanced DDR4-2133 memory, achieving amazingly high reading and writing speeds. MSI True Color technology ensures that each panel in a MSI notebook comes with amazing precision in color. Hence, each color is delivered with precision in detail for excellent color fidelity. And wide-viewing angle display allows you to experience better image quality with vivid colors and consistent brightness levels whether you're looking at the screen from above, below, the front or the side.
  • Load games in seconds
    Get in the game before everyone else with PCI-E Gen 3.0 utilizing NVMe technology. Harness the full performance potential of the Gen 3.0, ensuring extreme read and write speeds.
  • Boost performance under controlled noise & temperature
    The special MSI SHIFT technology pushes system to the extreme while minimizing noise and temperature. Switch between three profiles Sport, Comfort, and Green to reach balance between system performance and comfortable user experience.
  • DDR4-2133 memory support
  • Keep calm under pressure
    MSI advanced Cooler Boost 3 technology creates dual thermal modules internally by allocating dedicated heat pipes for GPU and CPU. One click on the fan boost button, and a total of 9 heat pipes and dual fans will actively and effectively push heat out of the system.
  • True Color technology
  • Matrix Display
    Expand the vision for extreme gaming experience. The Matrix Display technology supports up to 2 external displays. Multitasking is made possible even during competitive gameplays.
  • Wide-viewing angle display
    Experience better image quality, the wide-view angle panel boasts enhanced contrast level and brightness, with vivid colors and consistent brightness levels whether you're looking at the screen from above, below, the front or the side.
  • Nahimic virtual surround
    Designed to work with standard audio and stereo equipment, Nahimic transports gamers into the action, allowing them to sense every footstep, hear every bullet whizzing past, and feel every explosion. It also features a high-definition audio recorder to easily capture and stream studio quality.
  • Sound by Dynaudio 2.1 speaker system
    GT72 notebook is packing the advanced speakers design with 2 channels with 1 subwoofer, and absolutely authentic hearing experience. The signal has been enhanced and the volume has been increased; people who play games or enjoy movies will absolutely be immersed in the perfect system with outstanding sound effect.
  • Audio Boost 2 with 3 independent amps
    By utilizing dedicated headset amplifiers, an isolated audio board and gold-plated audio jacks, Audio Boost 2 delivers advanced listening and improves audio performance. Audio Boost 2 provides gamers a more detailed aural picture of their surroundings, helping in-game, while also minimizing distortion and providing a powerful amplifier which has no trouble powering even demanding gaming headsets. Gold-plated jacks will give you less noise interference and ensure the long-term durability of the jack.
  • Silver lining print
    See more and do more in the night with high-grade silver lining printed keys. See the full color spectrum on the SteelSeries multicolor keyboard and enjoy longer lasting keys worry free of long-term wear and tear.
  • Killer Gaming LAN - protecting your ping
    In the gaming battlefield, speed defines the winner. Stop losing games to lag with Killer Gaming Lan. The advanced stream detect protects networking traffic and prevents lag spikes through controlling and managing up to 6 priority levels. You can game without fear and play at your best while tracking your speeds with the easy-to-use Killer Networking Manager.
MSI GE72 6QD 033UK Apache Pro - 17.3" - Intel Core i7 6700HQ - 8 GB RAM - 128 GB SSD + 1 TB HDD
Notebook
Operating System
Windows 10 Home
Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz (3.5 GHz) / 6 MB Cache
8 GB DDR4
Storage
128 GB SSD + 1 TB HDD / 7200 rpm
Optical Drive
DVD SuperMulti
Display
17.3" LED backlight 1920 x 1080 / Full HD
Graphics
Video Memory
2 GB GDDR5 SDRAM
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
6-cell
41.99 cm x 28.78 cm x 3.2 cm
2.9 kg
Notebook
Operating System
Windows 10 Home
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Chipset
Mobile Intel HM170
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Storage
Main Storage
128 GB SSD SATA 6Gb/s
Secondary Storage
1 TB HDD SATA 6Gb/s / 7200 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Display
17.3"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Anti-glare, WideView, MSI Matrix Display, MSI True Colour Technology
Audio & Video
Graphics Processor
Video Memory
2 GB GDDR5 SDRAM
Camera
Yes - 720p
Sound
Stereo speakers, subwoofer, microphone
Audio Features
Output: 7.1 SPDIF, Dynaudio Premium Sound Technology, MSI Audio Boost 2, Nahimic sound technology
Input
Keyboard, touchpad
Keyboard Backlight
SteelSeries Engine 3, SteelSeries Full Color
Communications
Wireless
Network Interface
Gigabit Ethernet
Ethernet Controller
Killer Ethernet E2400
6-cell
AC Adapter
Output
120 Watt
Connections & Expansion
LAN , Microphone input , Headphone output , 2 x USB 3.0 , HDMI , Mini DisplayPort , USB 2.0 , USB-C
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
SteelSeries Engine 3, XSplit Gamecaster 2 (1 year Premium licence)
SteelSeries gaming keyboard, Cooler Boost 3 technology, MSI SHIFT Technology
Power adapter
2.9 kg
BVH4 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
