MSI Cubi-243WE White Intel Celeron 3215U 4GB 32GB Windows 10 IoT
Quicklinx: CWT4WS00 Mfr#: 9S6-B09612-243
  • Celeron
  • IEEE 802.11n
  • Bluetooth 4.0
With the extremely small mini-PC, the MSI Cubi suits the needs of both consumers and businesses, built on a concept of nifty technology and a brilliant design, that fits into any room. Featuring a powerful processor, combined with a unique hard drive box to expand extra hard drive for upgrade device capacities and plenty of ports to connect with external devices, Cubi is the essence of small, smart computing.
  • Ideal for countless applications
    The MSI Cubi is one of the extremely small mini-desktops, suited to serve as HTPC at home, all-round media PC in the office or commercial-project PC.
  • Smart design and neat style
    With curved edges, a smooth surface, a subtle ventilation frame and conveniently positioned I/O ports, the MSI Cubi is not only small, but also smart.
  • Expandable with extra hard drive
    MSI Cubi preinstalls a hard drive. Is it not enough? Base on MSI unique hard drive box modular design, Cubi offers the possibility to expand extra hard drive via hard drive box for a super-high-capacity data storage.
  • Supports powerful processor
    Built-in with the powerful processor - with an integrated GPU performance increase and total power consumption decrease - the Cubi is both powerful and energy-efficient at the same.
  • 4K Ultra HD support
    MSI Cubi supports HD and 4K (3840 x 2160) ultra-high-definition content, to serve as an HTPC, that helps to change your living room in a home theater, where you can enjoy the amazing display quality.
  • Dual display
    With dual display support (via HDMI and Mini DisplayPort) you can connect two monitors at the same time for an efficient day at the office.
  • Low power consumption
    This mini-PC is a true energy vanguard; in full loading the total power consumption is low, saving a lot of money on the energy bill.
  • Mountable to a monitor
    Cubi can be mounted to the back of a monitor, which makes the PC completely invisible on a desk. With such a low-noise PC, you won't even notice it's there at all!
MSI Cubi 243WE - mini PC - Celeron 3215U 1.7 GHz - 4 GB - SSD 32 GB
Personal computer - mini PC
Intel Celeron 3215U / 1.7 GHz (Dual-Core)
RAM
4 GB (installed) / 16 GB (max) - DDR3L SDRAM
Storage Controller
SATA
Hard Drive
SSD 32 GB - SATA - mSATA
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics
Audio Output
Stereo
1GbE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
OS Provided
Windows 10
White
11.52 cm x 11.22 cm x 3.26 cm
390 g
Environmental Standards
ENERGY STAR Qualified
Personal computer
Product Form Factor
Mini PC
White
Processor / Chipset
CPU
Intel Celeron 3215U
Clock Speed
1.7 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
RAM
Installed Size
4 GB / 16 GB (max)
DDR3L SDRAM
Effective Memory Speed
1333 MHz
SO-DIMM 204-pin
Slots
2 (Total)
Hard Drive
SSD - mSATA
1 x 32 GB
Interface Type
SATA
Storage Controller
1 x SATA
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Intel HD Graphics
Video Interfaces
HDMI, DisplayPort
Audio Output
Sound Output Mode
Stereo
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
Slots
1 (total) / 0 (free) x CPU , 2 SO-DIMM 204-pin
4 x USB 3.0 (2 front, 2 rear) (one of them is fast-charging) , 1 x headphones/microphone - mini-jack (1 in front) , 1 x HDMI output , 1 x LAN (Gigabit Ethernet) , 1 x Mini DisplayPort
Theft/Intrusion Protection
VESA Mounting Interface
RoHS
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
Windows 10
Sustainability Information
ENERGY STAR Certified
11.52 cm
11.22 cm
3.26 cm
390 g
