With the extremely small mini-PC, the MSI Cubi suits the needs of both consumers and businesses, built on a concept of nifty technology and a brilliant design, that fits into any room. Featuring a powerful processor, combined with a unique hard drive box to expand extra hard drive for upgrade device capacities and plenty of ports to connect with external devices, Cubi is the essence of small, smart computing.
Ideal for countless applications
The MSI Cubi is one of the extremely small mini-desktops, suited to serve as HTPC at home, all-round media PC in the office or commercial-project PC. -
Smart design and neat style
With curved edges, a smooth surface, a subtle ventilation frame and conveniently positioned I/O ports, the MSI Cubi is not only small, but also smart. -
Expandable with extra hard drive
MSI Cubi preinstalls a hard drive. Is it not enough? Base on MSI unique hard drive box modular design, Cubi offers the possibility to expand extra hard drive via hard drive box for a super-high-capacity data storage. -
Supports powerful processor
Built-in with the powerful processor - with an integrated GPU performance increase and total power consumption decrease - the Cubi is both powerful and energy-efficient at the same. -
4K Ultra HD support
MSI Cubi supports HD and 4K (3840 x 2160) ultra-high-definition content, to serve as an HTPC, that helps to change your living room in a home theater, where you can enjoy the amazing display quality. -
Dual display
With dual display support (via HDMI and Mini DisplayPort) you can connect two monitors at the same time for an efficient day at the office. -
Low power consumption
This mini-PC is a true energy vanguard; in full loading the total power consumption is low, saving a lot of money on the energy bill. -
Mountable to a monitor
Cubi can be mounted to the back of a monitor, which makes the PC completely invisible on a desk. With such a low-noise PC, you won't even notice it's there at all!
- MSI Cubi 243WE - mini PC - Celeron 3215U 1.7 GHz - 4 GB - SSD 32 GB
- Personal computer - mini PC
- Processor
- Intel Celeron 3215U / 1.7 GHz (Dual-Core)
- RAM
- 4 GB (installed) / 16 GB (max) - DDR3L SDRAM
- Storage Controller
- SATA
- Hard Drive
- SSD 32 GB - SATA - mSATA
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics
- Audio Output
- Stereo
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
- OS Provided
- Windows 10
- White
- 11.52 cm x 11.22 cm x 3.26 cm
- 390 g
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 2 years
- Personal computer
- Product Form Factor
- Mini PC
- White
Processor / Chipset
- CPU
- Clock Speed
- 1.7 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
RAM
- Installed Size
- 4 GB / 16 GB (max)
- Technology
- DDR3L SDRAM
- Effective Memory Speed
- 1333 MHz
- Form Factor
- SO-DIMM 204-pin
- Slots
- 2 (Total)
Hard Drive
- SSD - mSATA
- Capacity
- 1 x 32 GB
- Interface Type
- SATA
Storage Controller
- 1 x SATA
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Intel HD Graphics
- Video Interfaces
- HDMI, DisplayPort
Audio Output
- Sound Output Mode
- Stereo
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- Slots
- 1 (total) / 0 (free) x CPU , 2 SO-DIMM 204-pin
- 4 x USB 3.0 (2 front, 2 rear) (one of them is fast-charging) , 1 x headphones/microphone - mini-jack (1 in front) , 1 x HDMI output , 1 x LAN (Gigabit Ethernet) , 1 x Mini DisplayPort
- Theft/Intrusion Protection
- VESA Mounting Interface
- RoHS
- Power adapter
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- Windows 10
Sustainability Information
- ENERGY STAR Certified
- 11.52 cm
- 11.22 cm
- 3.26 cm
- 390 g
