Smart design & neat colors
With curved edges, a smooth surface, a subtle ventilation frame and conveniently positioned I/O ports, the MSI Cubi 2 is not only the smallest, but also the smartest in its kind. -
Hand palm-sized PC
Smaller than a lunchbox and less volume than a large soda can, MSI Cubi 2 is the smallest mini PC in its kind. With a 0.45 liter case that still provides all the elements of a desktop-worthy PC. With a sleek design, Cubi 2 is not just only a mini PC but fits with ease in any Livingroom. -
USB Gen1 Type-C with reversible design
Get all the performance benefits from USB 3.1 Gen1 combined with the convenience of the USB Type-C connector. This reversible connector allows for effortless connecting of USB devices. -
Easily extend your storage
Based on a modular design, the MSI Cubi 2 offers the possibility to install an additional 2.5" HDD for super high capacity data storage. Users can easily replace the bottom cover with an extended module, providing more space for those who desire more storage. -
Two-ball fan heatsink
Compared to the regular sleeve-bearing fans, Cubi 2 choose a two-ball fan heatsink to deliver ultra-durable and longer CPU protection. -
Mountable to a monitor
Cubi 2 is designed with a mini size and supports standard VESA-mount. Mount the Cubi 2 to the back of a monitor and make the PC completely invisible. -
Happiness all around
MSI Cubi 2 supports HD and 4K (3840 x 2160 @ 60 Hz) ultra-high-definition content, to serve as an HTPC that helps to change your living room in a home theater where you can enjoy the best display quality. -
Do more work simultaneously
Are you watching a lot of webpages and applications on a small monitor? With the HDMI and DP ports, MSI Cubi 2 can support dual monitors, you can do and view more.
- MSI Cubi 2 010UK - mini PC - Core i5 7200U 2.5 GHz - 8 GB - HDD 1 TB
- Personal computer - mini PC
- Processor
- Intel Core i5 (7th Gen) 7200U / 2.5 GHz (Dual-Core)
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- HDD 1 TB - SATA
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics 620
- Audio Output
- Stereo
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5
- OS Provided
- Windows 10 Home
- Black
- 11.52 cm x 11.22 cm x 4.27 cm
- 510 g
- Personal computer
- Product Form Factor
- Mini PC
- Black
Processor / Chipset
- CPU
- Clock Speed
- 2.5 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel H110 Express
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total)
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
- Max Monitors Supported
- 2
Audio Output
- Sound Output Mode
- Stereo
- Ethernet Controller
- Realtek RTL8111H
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 3168
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Bays
- 1 (total) / 0 (free) x internal 2.5"
- Slots
- 1 (total) / 0 (free) x CPU , M.2 Card , 2 SO-DIMM 260-pin
- 1 x headphones - mini-jack (1 in front) , 1 x microphone - mini-jack (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x HDMI output , 1 x Mini DisplayPort , 1 x USB-C 3.1 Gen 1 (1 in front) , 3 x USB 3.1 Gen 1 (1 front, 2 rear)
- Theft/Intrusion Protection
- VESA Mounting Interface
- Power adapter
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- Windows 10 Home
- 11.52 cm
- 11.22 cm
- 4.27 cm
- 510 g
- Sound Emission
- 23.7 dB
