MSI Cubi 2-003XEU Intel Core i5-7200U 8GB 1TB Windows 10 Home
Quicklinx: CWT1WS00 Mfr#: 9S6-B14211-010
  • Core i5
  • IEEE 802.11n
  • Smart design & neat colors
    With curved edges, a smooth surface, a subtle ventilation frame and conveniently positioned I/O ports, the MSI Cubi 2 is not only the smallest, but also the smartest in its kind.
  • Hand palm-sized PC
    Smaller than a lunchbox and less volume than a large soda can, MSI Cubi 2 is the smallest mini PC in its kind. With a 0.45 liter case that still provides all the elements of a desktop-worthy PC. With a sleek design, Cubi 2 is not just only a mini PC but fits with ease in any Livingroom.
  • USB Gen1 Type-C with reversible design
    Get all the performance benefits from USB 3.1 Gen1 combined with the convenience of the USB Type-C connector. This reversible connector allows for effortless connecting of USB devices.
  • Easily extend your storage
    Based on a modular design, the MSI Cubi 2 offers the possibility to install an additional 2.5" HDD for super high capacity data storage. Users can easily replace the bottom cover with an extended module, providing more space for those who desire more storage.
  • Two-ball fan heatsink
    Compared to the regular sleeve-bearing fans, Cubi 2 choose a two-ball fan heatsink to deliver ultra-durable and longer CPU protection.
  • Mountable to a monitor
    Cubi 2 is designed with a mini size and supports standard VESA-mount. Mount the Cubi 2 to the back of a monitor and make the PC completely invisible.
  • Happiness all around
    MSI Cubi 2 supports HD and 4K (3840 x 2160 @ 60 Hz) ultra-high-definition content, to serve as an HTPC that helps to change your living room in a home theater where you can enjoy the best display quality.
  • Do more work simultaneously
    Are you watching a lot of webpages and applications on a small monitor? With the HDMI and DP ports, MSI Cubi 2 can support dual monitors, you can do and view more.
MSI Cubi 2 010UK - mini PC - Core i5 7200U 2.5 GHz - 8 GB - HDD 1 TB
Personal computer - mini PC
Intel Core i5 (7th Gen) 7200U / 2.5 GHz (Dual-Core)
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
HDD 1 TB - SATA
Optical Storage
No optical drive
Graphics Controller
Intel HD Graphics 620
Audio Output
Stereo
1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5
OS Provided
Windows 10 Home
11.52 cm x 11.22 cm x 4.27 cm
510 g
Personal computer
Product Form Factor
Mini PC
Processor / Chipset
CPU
Clock Speed
2.5 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
8 GB / 32 GB (max)
DDR4 SDRAM
Effective Memory Speed
2133 MHz
SO-DIMM 260-pin
Slots
2 (Total)
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Max Monitors Supported
2
Audio Output
Sound Output Mode
Stereo
Ethernet Controller
Realtek RTL8111H
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 3168
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Bays
1 (total) / 0 (free) x internal 2.5"
Slots
1 (total) / 0 (free) x CPU , M.2 Card , 2 SO-DIMM 260-pin
1 x headphones - mini-jack (1 in front) , 1 x microphone - mini-jack (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x HDMI output , 1 x Mini DisplayPort , 1 x USB-C 3.1 Gen 1 (1 in front) , 3 x USB 3.1 Gen 1 (1 front, 2 rear)
Theft/Intrusion Protection
VESA Mounting Interface
Power adapter
Power Provided
65 Watt
Operating System / Software
OS Provided
Windows 10 Home
11.52 cm
11.22 cm
4.27 cm
510 g
Sound Emission
23.7 dB
