MSI B350M MORTAR AM4 DDR4 PCIe M.2 SATA6Gb/s USB3.1Gen1
Quicklinx: CQZXWS00 Mfr#: B350M MORTAR
B350M MORTAR
Blast away the competition
1GAMING Device Port
2HDMI, DisplayPort
3GAMING LAN
4USB 3.1 Type-A, Type-C
5Golden audio jacks with S/PDIF
MSI B350M MORTAR overview
6Heavy plated gaming heatsinks
Leading heatsink design, for maximum cooling
7DDR4 Boost
Optimized traces and isolated memory circuitry
8PCI-E Steel Armor
Protecting VGA cards against bending and EMI
9Turbo M.2
NVMe support, up to 32 Gb/s using PCI-Express Gen3 x4
10Audio Boost
Optimized gaming audio using best components
11Click BIOS 5
A gamers BIOS
Personalize your Gaming Rig
Connect external RGB strips and sync other RGB capable gear to set up your own color scheme using only 1 application: Mystic Light Sync. Select any of the colors from the palette using your smartphone or the MSI Gaming App to match your system style. Feel like using a different color? Completely change the look of your system in 1 second!
Mystic Light Sync logo
Customize colorsCustomize effectsMystic Light AppMystic Light Extension
Works with certified Mystic Light Sync products:
Mystic Light vendors
Fully controllable fan headers
MSI FAN headers automatically detect fans running in DC or PWM mode for optimal tuning of fan speeds and silence. Hysteresis also makes your fans spin up fluently to make sure your system stays silent, no matter what.
 Fan Headers
Fan controlFan Headers
Your in-game advantage
Outsmart and outperform your opponents in-game using an array of unique MSI GAMING tools. Clever hardware & software tools, created to keep you one step ahead of the competition and boost your skills.
Gaming HotkeyGaming Device port
Multi-GPU1 second overclocking
Multi GPUGame Boost 1 second overclocking
X-Boost your Storage Performance
When enabled, X-Boost auto-detects and optimizes your SSDs to keep your system fast and maximize storage performance, making sure you reach the battlefield even quicker or saving you a lot of time when transferring data.
X-boost performance
Immerse yourself into Virtual Worlds
Want the best of the best VR experience without any compromise? Through joint efforts with major VR brands, combined with unique MSI features geared to VR, MSI brings gamers and VR professionals a vivid, smooth and realistic experience in which content truly comes alive.
VR ReadyHTC Vive
HTC Vive
Amplify your Game with Audio Boost
Like a dedicated sound card Audio Boost offers a HD audio processor, dedicated amplifier and high quality audio capacitors, all physically isolated from the rest of the motherboard circuitry to ensure the purest audio signal to locate enemies with pin-point accuracy.
Isolated Audio with LED LineChemi-Con Audio capacitors
Isolated audio design with Isolated Audio with LED LineChemi-con Audio Capacitors
Audio Boost logo
Audio Boost Ohm chart
Dominate the Game with the Lowest Latency
Get ready to crush your enemies on the battlefield with MSI GAMING LAN. Featuring the highest quality components tuned to deliver the best online gaming experience without lag.
Optimize Killer Gaming LAN
Unmatched Memory Performance
MSI motherboards are crammed with features to fuel your gaming rig’s memory with more speed, higher overclockability and increased stability.
Memory Signal PurityMSIMSI captionOthersMSI caption
DDR4 Boost performance
Best compatibility
Optimized traces and a fully isolated memory circuitry ensures perfect stability and performance, so you never have to worry about your system crashing during games.
Best compatibility chart
Maximize your USB Device performance
Transfer your favorite games, music and movies over USB faster than ever. MSI offers a wide variety of options to connect and boost your USB 3.1 devices, delivering lightning-fast transfer speeds!
No strengthening others
Reversible connector
Up to 20% faster with XBoost
XBoost performance
Built on everlasting quality
Only the finest quality components and latest innovations are used. Rigorous quality testing under the most extreme conditions ensures a super reliable, high performance motherboard.
Others
No strengthening
Strengthening-steel-armor Steel Armor
MSI Steel armor
Reinforced, heavy soldered connections
Steel Armor slot
Reinforced Steel PCIe Slot, Protects Against EMI
  • Personalize your gaming rig
    Customize and set up your own color scheme with RGB mystic light sync. Select any of the colors from the palette using your smartphone or the MSI Gaming App to match your system style. Bored of the same colors? Simply change the complete look of your system in 1 second!
  • Stay cool while gaming
    Cooling your PC is essential for reliable performance. We've made sure to include enough fan headers with full control to allow you to cool your system any way you want.
  • Your in-game advantage
  • Be the first on the battlefield
    This MSI GAMING motherboard supports all the latest storage standards. This allows you to connect any ultra-fast storage device, giving you in-game benefits. Start games faster, load levels faster and have a real advantage over your enemies.
  • Mmerze yourself into virtual worlds
    Integrating the very best of cutting edge technologies on MSI hardware provides a smooth VR ride. Through joint efforts with major VR brands, combined with unique MSI features geared to VR, MSI brings gamers and VR professionals a vivid and realistic experience in which content truly comes alive.
  • Sound that pulls you into the game
    Get the most immersive sound experience when gaming. MSI Audio Boost delivers the highest sound quality through the use of premium quality audio components. This lets you enjoy breathtaking, game-changing sound to create the most exciting gameplay.
MSI B350M MORTAR - motherboard - micro ATX - Socket AM4 - AMD B350 FCH
Motherboard - micro ATX
Chipset Type
AMD B350 FCH
Processor Socket
1 x Socket AM4
Compatible Processors
Athlon, A series, Ryzen (supports 7th Generation A-series / Athlon)
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, ECC (operate in non-ECC mode), unbuffered
Storage Ports
4 x SATA-600 (RAID), 1 x M.2
USB / FireWire Ports
1 x USB-C Gen 1 + 3 x USB 3.1 Gen 1 + 2 x USB 2.0 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
AMD B350 FCH
Processor Socket
Socket AM4
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2400 MHz, 1866 MHz, 2133 MHz, 2933 MHz (O.C.), 2667 MHz (O.C.), 3200 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC, ECC (operate in non-ECC mode)
Registered or Buffered
Unbuffered
Dual channel memory architecture, supported ECC modules operate in non-ECC mode
Audio
Audio Codec
Realtek ALC892
High Definition Audio
LAN
Network Controller
Realtek RTL8111H
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 (x16 mode (with AMD Ryzen CPU); x8 mode (with AMD 7th Generation A-series/Athlon CPU)) , 2 x PCIe 2.0 x1 , 1 x PCIe 2.0 x16 (x4 mode)
Storage Interfaces
SATA-600 -connectors: 4 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2
1 x LAN (Gigabit Ethernet) , 1 x USB-C Gen1 , 1 x PS/2 keyboard / mouse , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x DisplayPort , 1 x DVI-D , 1 x HDMI , 3 x USB 3.1 Gen 1 , 2 x USB 2.0 , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x TOSLINK
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x serial - header , 1 x parallel - header , 1 x audio - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
MSI ClickBIOS 5
Hardware Features
AMD CrossFireX technology support, MSI Military Class IV, MSI Audio Boost, MSI Gaming Device Port, MSI Guard-Pro, Debug LED, MSI Mystic Light, MSI Steel Armor, Game Boost, LAN Protect, MSI Ambient LED
Software Included
RAMdisk, MSI Gaming Hotkey, MSI Gaming LAN Manager, MSI X-BOOST
WHQL
24.3 cm
24.3 cm
