Supports AMD RYZEN Series processors and 7th Gen A-series / Athlon Processors for socket AM4. Supports DDR4-3200+(OC) Memory. DDR4 Boost: Give your DDR4 memory a performance boost. VR Ready: Best virtual reality game experience without latency. Lightning Fast Game experience: Turbo M.2, Lightning USB 3.1 Gen2. Audio Boost: Reward your ears with studio grade sound quality for the most immersive gaming experience. GAMING LAN with LAN Protect: The best online gaming experience with lowest latency and bandwidth management. Military Class 4, Guard-Pro: Latest evolution in high quality components for best protection and efficiency. MULTI-GPU: With Steel Armor PCI-E slots. Supports AMD Crossfire . Mystic Light Sync: Synchronize other RGB solutions with your gaming rig and control all LEDs in one click. In-Game Weapons: Game Boost, GAMING Hotkey, X-Boost, Xsplit Gamecaster. EZ Debug LED: Easiest way to troubleshoot. Click BIOS 5: Award-winning BIOS with high resolution scalable font, favorites and search function. GAMING CERTIFIED: 24-hour on- and offline game and motherboard testing by eSports players.
Stay cool while gaming
Cooling your PC is essential for reliable performance. Enough fan headers with full control are provided to allow you to cool your system any way you want. -
Be the first on the battlefield
This MSI gaming motherboard supports many storage standards. This allows you to connect any ultra-fast storage device, giving you in-game benefits. Start games faster, load levels faster and have a real advantage over your enemies. -
Dominate the game with low latency
Get ready to crush your enemies on the battlefield with MSI gaming LAN. Featuring the high quality components tuned to deliver the perfect online gaming experience without lag. -
Unmatched memory performance
MSI motherboards are crammed with features to fuel your gaming rig's memory with more speed, higher overclockability and increased stability. -
Maximize your USB device performance
Transfer your favorite games, music and movies over USB faster than ever. MSI offers a wide variety of options to connect and boost your USB 3.1 devices, delivering lightning-fast transfer speeds!
- MSI B350 KRAIT GAMING - motherboard - ATX - Socket AM4 - AMD B350 FCH
- Product Type
- Motherboard - ATX
- Chipset Type
- AMD B350 FCH
- Processor Socket
- 1 x Socket AM4
- Compatible Processors
- Athlon, A series, Ryzen (supports 7th Generation A-series / Athlon)
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4, non-ECC, ECC (operate in non-ECC mode), unbuffered
- Storage Ports
- 2 x SATA-600 (RAID), 2 x SATA-600, 1 x M.2
- USB / FireWire Ports
- 1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
- Max Allocated RAM Size
- 2048 MB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- AMD B350 FCH
- Processor Socket
- Socket AM4
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2400 MHz, 1866 MHz, 2133 MHz, 2933 MHz (O.C.), 2667 MHz (O.C.), 3200 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC, ECC (operate in non-ECC mode)
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, supported ECC modules operate in non-ECC mode
Graphics
- 2048 MB
Audio
- Audio Codec
- Realtek ALC892
- High Definition Audio
LAN
- Network Controller
- Realtek RTL8111H
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 (x16 mode (with AMD Ryzen CPU); x8 mode (with AMD 7th Generation A-series/Athlon CPU)) , 3 x PCIe 2.0 x1 , 1 x PCIe 2.0 x16 (x4 mode)
- Storage Interfaces
- SATA-600 -connectors: 2 x 7pin Serial ATA - RAID 0 / RAID 1 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2 , ASMedia ASM1061: SATA-600 -connectors: 2 x 7pin Serial ATA
- 1 x LAN (Gigabit Ethernet) , 4 x USB 3.1 Gen 1 , 1 x PS/2 keyboard / mouse , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x USB-C Gen2 , 1 x USB 3.1 Gen 2 , 1 x HDMI , 1 x DVI-D , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack , 2 x USB 2.0
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x serial - header , 1 x parallel - header , 1 x audio - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Features
- MSI ClickBIOS 5
- Hardware Features
- AMD CrossFireX technology support, MSI Military Class IV, MSI Audio Boost, MSI Gaming Device Port, MSI Guard-Pro, Debug LED, MSI Mystic Light, MSI Steel Armor, Game Boost, LAN Protect, Nahimic 2 Sound Technology
- Software Included
- RAMdisk, MSI Gaming Hotkey, MSI Gaming LAN Manager, MSI X-BOOST
- WHQL
- 30.4 cm
- 24.3 cm
