Supports AMD RYZEN Series processors and 7th Gen A-series / Athlon Processors for socket AM4. Supports DDR4-3200+(OC) Memory. DDR4 Boost: Give your DDR4 memory a performance boost. VR Ready: Best virtual reality game experience without latency. Lightning Fast Game experience: Turbo M.2. Audio Boost: Reward your ears with studio grade sound quality for the most immersive gaming experience. GAMING LAN with LAN Protect: The best online gaming experience with lowest latency and bandwidth management. Military Class 4, Guard-Pro: Latest evolution in high quality components for best protection and efficiency. MULTI-GPU: With Steel Armor PCI-E slots. Supports AMD Crossfire . Mystic Light Sync: Synchronize other RGB solutions with your gaming rig and control all LEDs in one click. In-Game Weapons: Game Boost, GAMING Hotkey, X-Boost. EZ Debug LED: Easiest way to troubleshoot. Click BIOS 5: Award-winning BIOS with high resolution scalable font, favorites and search function. GAMING CERTIFIED: 24-hour on- and offline game and motherboard testing by eSports players.
Personalize your gaming RIG
Customize and set up your own color scheme with RGB Mystic Light. Select any of the colors from the palette to match your system style. Bored of the same colors? Simply change the complete look of your system in a jiffy! -
Stay cool while gaming
Cooling your PC is essential for reliable performance. This motherboard has enough fan headers with full control to allow you to cool your system any way you want. -
Dominate the game with low latency
Get ready to crush your enemies on the battlefield with MSI gaming LAN, featuring the high quality components tuned to deliver perfect online gaming experience without lag. -
Unmatched memory performance
MSI motherboards are crammed with features to fuel your gaming rig's memory with more speed, higher overclockability and increased stability.
- MSI B350 GAMING PLUS - motherboard - ATX - Socket AM4 - AMD B350 FCH
- Product Type
- Motherboard - ATX
- Chipset Type
- AMD B350 FCH
- Processor Socket
- 1 x Socket AM4
- Compatible Processors
- Athlon, A series, Ryzen (supports 7th Generation A-series / Athlon)
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4
- Storage Ports
- 4 x SATA-600 (RAID), 1 x M.2
- USB / FireWire Ports
- 1 x USB-C Gen 1 + 3 x USB 3.1 Gen 1 + 2 x USB 2.0 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
- Max Allocated RAM Size
- 2048 MB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- AMD B350 FCH
- Processor Socket
- Socket AM4
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2400 MHz, 1866 MHz, 2133 MHz, 2933 MHz (O.C.), 2667 MHz (O.C.), 3200 MHz (O.C.)
- Dual channel memory architecture
Graphics
- 2048 MB
Audio
- Audio Codec
- Realtek ALC892
- High Definition Audio
LAN
- Network Controller
- Realtek RTL8111H
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 (x16 mode (with AMD Ryzen CPU); x8 mode (with AMD 7th Generation A-series/Athlon CPU)) , 2 x PCIe 2.0 x1 , 1 x PCIe 2.0 x16 (x4 mode) , 2 x PCI
- Storage Interfaces
- SATA-600 -connectors: 4 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2
- 1 x LAN (Gigabit Ethernet) , 3 x USB 3.1 Gen 1 , 1 x PS/2 keyboard / mouse , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x USB-C Gen1 , 1 x HDMI , 1 x DVI-D , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (side surround) - mini-jack , 2 x USB 2.0 , 1 x VGA
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x serial - header , 1 x parallel - header , 1 x audio - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Features
- MSI ClickBIOS 5
- Hardware Features
- AMD CrossFireX technology support, MSI Military Class IV, MSI Audio Boost, MSI Gaming Device Port, MSI Guard-Pro, Debug LED, MSI Mystic Light, MSI Steel Armor, Game Boost, LAN Protect
- Software Included
- RAMdisk, MSI Gaming App, MSI Gaming Hotkey, MSI Gaming LAN Manager, MSI X-BOOST
- WHQL
- 30.4 cm
- 24.3 cm
