MSI B150I GAMING PRO AC Intel S1151 DDR4 USB3.0 PCIe SATA3 M.2
Quicklinx: BQKPWS00 Mfr#: B150I GAMING PRO AC
  • Bluetooth 4.0
  • Bluetooth 3.0
  • IEEE 802.11n
Each game demands different skills, each gamer selects, customizes and levels their own gaming character. Why stop there? MSI Performance GAMING motherboards allow you to fully customize & personalize your gaming PC to any color you want while delivering top performance for a great gaming experience.
With traditional memory design the memory signals are often distorted by electromagnetic signals from other components, making the system perform slower or become unstable. MSI introduces DDR4 Boost technology with optimized traces and fully isolated memory circuitry. This design ensures the memory signals stay pure for optimal performance and stability.
Customize and set up your own color scheme with mystic light. Make your build look on fire or cold as ice. You are in control. You can select any of the colors from the palette to match your systems' design. Tired of always the same color? Just change it to another one using the easy to use GAMING App, and make your PC look & feel brand new!
  • Game in style
  • Unmatched memory performance and stability
  • Mystic light
  • Dominate the game with lowest latency
    Get ready to crush your enemies on the battlefield with MSI GAMING LAN, featuring carefully selected components to ensure the best online gaming experience without lag.
  • Dedicated gaming LAN with Intel
    Experience a more fluid game with Intel i219 LAN. Intel i219 LAN is designed to deliver high performance when gaming, delivering more throughput than other solutions.
  • Gaming optimized bandwith management
    Dedicated to giving you the best online gaming experience with optimized traffic prioritization and low latency, MSI GAMING LAN Manager automatically classifies and prioritizes the latency-sensitive applications for online games.
  • LAN protect
    Featuring 15 KV anti-surge protection to shield your network from lightning strikes and static electricity, LAN protect is a LAN connector designed to give you the best networking experience. It's highlighted with a red LED inside the RJ45 connector to show its functionality.
  • Studio grade sound with Audio Boost 3
    With Audio Boost 3, you will have the highest sound quality through the use of premium quality audio components. That way, you can enjoy breathtaking, crystal clear sound and music through 8-channel HD Audio or high impendence headphones and truly dominate the game.
  • Gaming hotkey
    Gaming hotkey enables more functionality using your own keyboard. Simply assign functions or macros to any key and launch your favorite games, load overclocking profiles or do real-time overclocking with the push of a single button. The possibilities are endless!
  • Total freedom, maximum ease
    Easily program your most used commands to be executed with a single keystroke. You are free to choose any key you want.
  • MSI USB 3.1 Gen2
    Transferring your favorite games, music and movies over USB has never been faster. USB 3.1 Gen2 enables lightning fast transfer speeds up to 10 Gb/s!
  • Fast storagewith SATA Express
    SATA Express offers a solution in high speed storage through PCI-Express, providing more bandwidth for the generation SSDs up to 16 Gb/s.
  • Enhanced CPU overvoltage protection
    Onboard overvoltage protection prevents overvoltage and short-circuit damage of the CPU and other components. A red LED near the 24 pin CPU power connector let you know that overvoltage protection is activated for easier troubleshooting.
  • Easy diagnostic
    MSI EZ debug LED is an easy troubleshooting tool using 3 LEDs to indicate CPU/memory/VGA operation every time you boot up your system. Run into trouble? Use the LEDs to easily identify the source of your problem and get back into operation quickly.
MSI B150I GAMING PRO AC - motherboard - mini ITX - LGA1151 Socket - B150
Motherboard - mini ITX
Chipset Type
Intel B150
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR4
Storage Ports
4 x SATA-600, 1 x M.2
USB / FireWire Ports
2 x USB 3.1 Gen 1 + 4 x USB 2.0 + (2 x USB 3.1 Gen 1 + 2 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Bluetooth, Gigabit Ethernet, 802.11a/b/g/n/ac
Chipset Type
Intel B150
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR4
Bus Clock
2133 MHz
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Interfaces
Expansion Slots
1 x CPU , 2 x DIMM 288-pin , 1 x PCIe 3.0 x16
Storage Interfaces
SATA-600 / PCIe 3.0 -connectors: 4 x 7pin SATA, 1 x M.2
1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 1 x DVI-D , 1 x HDMI , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x PS/2 keyboard / mouse , 2 x USB 3.1 Gen 1
Internal Interfaces
2 x USB 2.0 - header , 2 x USB 3.1 Gen 1 - header , 1 x audio - header , 1 x serial - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Features
UEFI BIOS, MSI ClickBIOS 5
Hardware Features
Intel Extreme Memory Profile (XMP) support, Intel Wireless Display (WiDi), MSI Military Class IV, MSI Audio Boost, MSI Gaming Device Port, MSI Guard-Pro, Debug LED, Game Boost, Double ESD Protection, SteelSeries Certified (SSC), MSI VGA Armor, overvoltage protection
2 aerials
Software Included
RAMdisk, MSI Gaming Hotkey, MSI Gaming LAN Manager, MSI DPC Latency Tuner
WHQL
17 cm
17 cm
