The MSI® B150 GAMING M3 motherboard is designed to provide gamers the best gaming experience through genuine GAMING design, best-in-class gaming features and the latest technology. The B150 GAMING M3 motherboard is an engineering masterpiece tailored to gaming perfection.
DDR4 BOOST
By fully isolating the memory circuitry from other components, DDR4 Boost ensures the memory signal to stay pure for maximum performance and stability.
M.2 & SATA Express
Enjoy a blazing fast system boot up and insanely fast loading times with MSI GAMING motherboards. M.2 and SATA Express transfer data up to 16 Gb/s, making it 67% faster than SATA 3.0.
AUDIO BOOST 3 & NAHIMIC
The ultimate audio solution for gamers, powered by Nahimic Audio Enhancer. With dual OPA1652 AMPs and metal EMI Shielding you get breathtaking sound quality.
MSI GAMING LAN POWERED BY KILLER™
MSI GAMING LAN is powered by the KillerTM LAN E2400 Network Controller featuring intelligent AES 2.0 to automatically prioritize games above other applications. GAMING LAN uses LAN Protect with 15KV anti-surge protection for safety, highlighted with a red LED in the LAN port.
- MSI B150 GAMING M3 - motherboard - ATX - LGA1151 Socket - B150
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel B150
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4, ECC, unbuffered
- Storage Ports
- 6 x SATA-600, 1 x SATA Express port, 1 x M.2
- USB / FireWire Ports
- 4 x USB 3.1 Gen 1 + 4 x USB 2.0 + (2 x USB 3.1 Gen 1 + 2 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel B150
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz
- Supported RAM Integrity Check
- ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Audio
- Audio Codec
- Realtek ALC1150
- High Definition Audio
LAN
- Network Controller
- Killer Gaming E2400
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 (x16 mode) , 1 x PCIe 3.0 x16 (x16 mode (x1 mode if neighbour slot is occupied)) , 2 x PCIe 3.0 x1 , 3 x PCI
- Storage Interfaces
- SATA-600 / PCIe 3.0 -connectors: 6 x 7pin SATA, 1 x M.2, 1 x SATA Express port
- 1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 1 x DVI-D , 1 x HDMI , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x PS/2 keyboard / mouse , 4 x USB 3.1 Gen 1 , 1 x TOSLINK
- Internal Interfaces
- 2 x USB 2.0 - header , 2 x USB 3.1 Gen 1 - header , 1 x audio - header , 1 x serial - header , 1 x parallel - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Features
- DMI support, MSI ClickBIOS 5
- Hardware Features
- Intel Extreme Memory Profile (XMP) support, AMD CrossFireX technology support, MSI Gaming Device Port, Debug LED, Nahimic Audio Enhacer, MSI Audio Boost 3, MSI Military Class V, LAN Protect, Double ESD Protection, OC Essentials, SteelSeries Certified (SSC), MSI VGA Armor, overvoltage protection
- Included Accessories
- I/O back plate, "Do-Not-Disturb" door hanger, case badge, cable labels
- Software Included
- RAMdisk, MSI Gaming App, MSI Gaming Hotkey, MSI Gaming LAN Manager
- Plug and Play
- 30.4 cm
- 24.4 cm
