DEMAND MORE, DEMAND RADEON
Guiding the Future of Gaming
The 4th generation GCN architecture is engineered for gamers who play anything from the latest MOBA’s to the most popular AAA titles. Asynchronous Shaders and an enhanced Geometry Engine power new levels of smooth gameplay performance.
Immersive VR Experiences
Experience the next level of immersion with the world of VR gaming and entertainment with Radeon RX graphics cards powered by the revolutionary Polaris architecture.
AMD FreeSync™ Technology
Puts an end to choppy gameplay and broken frames with fluid, artifact-free performance at virtually any framerate.
HDR compatible
Enhanced contrast and colors deliver a strikingly sharp, colorful, and vivid visual experience
Core/Memory
• Boost Clock / Memory Frequency
1254 MHz / 6700 MHz (OC Mode)
1242 MHz / 6600 MHz (Gaming Mode)
1206 MHz / 6600 MHz (Silent Mode)
• 8192 MB GDDR5
Video Output Function
DisplayPort x 2
HDMI x 2
DL-DVI-D
TORX 2.0 FAN
Teamwork for greater strength
Just like in games, the exclusive MSI TORX 2.0 Fan technology uses the power of teamwork to allow the TWIN FROZR VI to achieve new levels of cool.
TORX 2.0 Fan design generates 22% more air pressure for supremely silent performance in the heat of battle.
Zero Frozr - Stay undetected
First introduced in 2008 by MSI, ZeroFrozr technology has made its mark and is now the industry standard among graphics cards. It eliminates fan noise by stopping the fans in low-load situations. This means you can focus on gaming without the noise of spinning fans.
Catch the Vibe with Cool LED Effects
Each LED can be controlled individually by choosing any of the animation effects availiable in the MSI Gaming App, ranging from responding to your game sounds or music to steady light, breathing and flashing. Of course, you can also turn them off.
Guiding the future of gaming
The 4th generation GCN architecture is engineered for gamers who play anything from the latest MOBA's to the most popular AAA titles. Asynchronous Shaders and an enhanced Geometry Engine power new levels of smooth gameplay performance. -
Immersive VR experiences
Experience the next level of immersion with the world of VR gaming and entertainment with Radeon RX graphics cards powered by the revolutionary Polaris architecture. -
AMD FreeSync technology
Puts an end to choppy gameplay and broken frames with fluid, artifact-free performance at virtually any framerate. -
HDR compatible
Enhanced contrast and colors deliver a strikingly sharp, colorful, and vivid visual experience. -
Zero Frozr-stay undetected
First introduced in 2008 by MSI, ZeroFrozr technology has made its mark and is now the industry standard among graphics cards. It eliminates fan noise by stopping the fans in low-load situations. This means you can focus on gaming without the noise of spinning fans. -
Catch the vibe with cool led effects
Each LED can be controlled individually by choosing any of the animation effects availiable in the MSI Gaming App, ranging from responding to your game sounds or music to steady light, breathing and flashing. Of course, you can also turn them off. -
Solid baseplate
To temper the heat generated by a powerful GPU, MSI GAMING series graphics cards use a solid nickel-plated copper base plate. The base plate catches the heat from the GPU and transfers it to the heat pipes for dissipation so you can keep cool.
- MSI RX 470 GAMING X 8G - graphics card - Radeon RX 470 - 8 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- AMD Radeon RX 470
- Memory
- 8 GB GDDR5
- Core Clock
- 1254 MHz
- Effective Memory Clock
- 6.7 GHz
- Memory Interface
- 256-bit
- Max Monitors Supported
- 4
- Interfaces Details
- 2 x HDMI , 2 x DisplayPort , DVI-D (dual link)
- API Supported
- DirectX 12, OpenGL 4.5
- 3.7 cm x 27.6 cm x 14 cm
- Graphics card
- Bus Type
- Graphics Engine
- AMD Radeon RX 470
- Core Clock
- 1254 MHz
- VR Ready
- 4
- API Supported
- High dynamic-range (HDR) rendering, MSI Solid Capacitor, AMD CrossFireX Technology, MSI Afterburner, Graphics Core Next (GCN), MSI Gaming App, Hi-C CAP, Super Ferrite Chokes, Airflow Control technology, FreeSync Technology, MSI Zero Frozr technology, LED illuminated MSI Gaming Dragon, AMD VR Ready Premium, Torx 2.0 Fans, Twin Frozr VI Thermal Design, HDCP
- Size
- 8 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6.7 GHz
- Bus Width
- 256-bit
- Required Power Supply
- 450 W
- Additional Requirements
- 8 pin PCI Express power connector
- 110 Watt
- Software Included
- MSI Afterburner, MSI Gaming App, XSplit Gamecaster 2 (1 year Premium licence), WTFast Gamers Private Network (2 months Premium licence)
- 3.7 cm
- 27.6 cm
- 14 cm
- 774 g
