DEMAND MORE, DEMAND RADEON
Guiding the Future of Gaming
The 4th generation GCN architecture is engineered for gamers who play anything from the latest MOBA’s to the most popular AAA titles. Asynchronous Shaders and an enhanced Geometry Engine power new levels of smooth gameplay performance.
Immersive VR Experiences
Experience the next level of immersion with the world of VR gaming and entertainment with Radeon RX graphics cards powered by the revolutionary Polaris architecture.
AMD FreeSync™ Technology
Puts an end to choppy gameplay and broken frames with fluid, artifact-free performance at virtually any framerate.
HDR compatible
Enhanced contrast and colors deliver a strikingly sharp, colorful, and vivid visual experience.
TORX 2.0 FAN
Teamwork for greater strength
Just like in games, the exclusive MSI TORX 2.0 Fan technology uses the power of teamwork to allow the TWIN FROZR VI to achieve new levels of cool.
TORX 2.0 Fan design generates 22% more air pressure for supremely silent performance in the heat of battle.
Zero Frozr-Stay undetected
First introduced in 2008 by MSI, ZeroFrozr technology has made its mark and is now the industry standard among graphics cards. It eliminates fan noise by stopping the fans in low-load situations. This means you can focus on gaming without the noise of spinning fans.
Catch the Vibe with Cool LED Effects
Each LED can be controlled individually by choosing any of the animation effects availiable in the MSI Gaming App, ranging from responding to your game sounds or music to steady light, breathing and flashing. Of course, you can also turn them off.
HEATSINK
Lurking under the cover of the GAMING graphics card is an engineering masterpiece designed to keep the graphics card cool. Every tiny detail of the intricate heatsink plays an essential part in providing a cool & quiet gaming experience.
Airflow Control Technology
Using advanced aerodynamics, Airflow Control Technology directs more air directly onto the TWIN FROZR VI heat pipes. The special deflectors on the heat sink enlarge the surface area, which means lower temperatures and better gaming.
Solid Baseplate
To temper the heat generated by a powerful GPU, MSI GAMING series graphics cards use a solid nickel-plated copper base plate. The base plate catches the heat from the GPU and transfers it to the heat pipes for dissipation so you can keep cool.
Premium Thermal Compound
Every detail counts when it comes to creating the ultimate thermal design, which is why TWIN FROZR VI uses a premium thermal compound to make sure it outlives the competition.
Multi GPU
Gaming enthusiasts are always looking for more performance to get the ultimate experience. Using multiple graphics cards in SLI or Crossfire is a great way to find out just how good it gets. MSI GAMING graphics cards fully support multi GPU technologies.
4K UHD
Ultra-high resolution (UHD) delivers 4x the resolution of 1080p content, enabling much sharper and crisper images with delicate details during gaming.
Gaming App
The MSI Gaming App allows for one-click performance profiles that unlock extra performance for gaming or keep your card silent during light use. It also features the EyeRest tab, giving you easy access to image quality improving technology. The LED control tab gives you full control over your MSI GAMING LED lights to set the mood.
OC Mode
Maximum Performance through higher clock speeds and increased fan performance
Gaming Mode
The best balance between in-game performance and silence
Silent Mode
The best environment for minimal fan noise
Guiding the future of gaming
The 4th generation GCN architecture is engineered for gamers who play anything from the latest MOBA's to the most popular AAA titles. Asynchronous Shaders and an enhanced Geometry Engine power new levels of smooth gameplay performance. -
Immersive VR experiences
Experience the next level of immersion with the world of VR gaming and entertainment with Radeon RX graphics cards powered by the revolutionary Polaris architecture. -
AMD FreeSync technology
Puts an end to choppy gameplay and broken frames with fluid, artifact-free performance at virtually any framerate. -
HDR compatible
Enhanced contrast and colors deliver a strikingly sharp, colorful, and vivid visual experience. -
Zero Frozr-stay undetected
First introduced in 2008 by MSI, ZeroFrozr technology has made its mark and is now the industry standard among graphics cards. It eliminates fan noise by stopping the fans in low-load situations. This means you can focus on gaming without the noise of spinning fans. -
Catch the vibe with cool led effects
Each LED can be controlled individually by choosing any of the animation effects availiable in the MSI Gaming App, ranging from responding to your game sounds or music to steady light, breathing and flashing. Of course, you can also turn them off. -
Solid baseplate
- MSI RX 470 GAMING X 4G - graphics card - Radeon RX 470 - 4 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- AMD Radeon RX 470
- Memory
- 4 GB GDDR5
- Core Clock
- 1254 MHz
- Effective Memory Clock
- 6.7 GHz
- Memory Interface
- 256-bit
- Max Monitors Supported
- 4
- 2 x HDMI , 2 x DisplayPort , DVI-D (dual link)
- API Supported
- DirectX 12, OpenGL 4.5
- 3.7 cm x 27.6 cm x 14 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- AMD Radeon RX 470
- Core Clock
- 1254 MHz
- VR Ready
- 4
- API Supported
- High dynamic-range (HDR) rendering, AMD CrossFireX Technology, MSI Afterburner, Graphics Core Next (GCN), MSI Gaming App, Airflow Control technology, FreeSync Technology, MSI Zero Frozr technology, LED illuminated MSI Gaming Dragon, AMD VR Ready Premium, Torx 2.0 Fans, Twin Frozr VI Thermal Design, HDCP
- Size
- 4 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6.7 GHz
- Bus Width
- 256-bit
- Required Power Supply
- 450 W
- Additional Requirements
- 8 pin PCI Express power connector
- 110 Watt
- Software Included
- MSI Afterburner, MSI Gaming App, XSplit Gamecaster 2
- 3.7 cm
- 27.6 cm
- 14 cm
- 774 g
- Limited warranty - parts and labour - 3 years
