MSI AMD Radeon R5 230 (Low Profile)Graphics Card 2GB DVI HDMI DP
Quicklinx: B5P9WS00 Mfr#: R5 230 2GD3H LP
The AMD Radeon R5 230 GPU is the perfect solution for everyday computer users who are looking for discrete GPU performance. Multimedia performance improvements, extended desktops and accelerated apps are all part of the package, along with ultra-low power consumption.
  • AMD Eyefinity technology
    Expand your viewing horizon using AMD Eyefinity technology to create the ultimate multi-monitor desktop workstation.
  • AMD app acceleration
    Use your GPU to improve performance of everyday tasks such as web browsing, office applications and video rendering.
  • AMD CrossFire technology
    With outstanding performance scaling, a system equipped with AMD CrossFire technology system keeps you fragging while everyone else is reaching for an upgrade.
  • AMD HD3D technology
    Play 3D games, watch Blu-ray 3D videos and edit 3D photos on your 3D monitor, TV or projector.
  • DirectX 11
    Enjoy the excellent gaming features and enhancements with built-in DirectX 11 support.
MSI R5 230 2GD3H LP graphics card - Radeon R5 230 - 2 GB
Graphics card - low profile
Bus Type
PCI Express 2.1 x16
Graphics Engine
AMD Radeon R5 230
2 GB - GDDR3
Core Clock
625 MHz
Effective Memory Clock
1.066 GHz
RAMDAC
400 MHz
Memory Interface
64-bit
Max Resolution
4096 x 2160
Max Monitors Supported
2
DVI-D (dual link) , HDMI , VGA
API Supported
DirectX 11, OpenGL 4.1
Fanless
1.9 cm x 16.5 cm x 6.9 cm
Graphics card - low profile - fanless
Bus Type
PCI Express 2.1 x16
Graphics Engine
AMD Radeon R5 230
Core Clock
625 MHz
RAMDAC
400 MHz
Max Resolution
4096 x 2160 at 24 Hz
2
API Supported
MSI Solid Capacitor, MSI Afterburner , HDCP
Size
2 GB
GDDR3 SDRAM
Effective Clock Speed
1.066 GHz
Bus Width
64-bit
Bandwidth
160 GBps
Required Power Supply
400 W
20 Watt
Software Included
Drivers & Utilities, Adobe Acrobat Reader, MSI Live Update Series, Microsoft DirectX, MSI Live, MSI Afterburner, MSI StarOSD, MSI Dual Core Center, Norton Internet Security 2008 (60 days trial), MSI Predator
1.9 cm
16.5 cm
6.9 cm
198 g
