Product
Brand
MSI AMD FM2+ A88X DDR3 USB3.0 GBE LAN VGA HDMI
Quicklinx: BDYLWS00 Mfr#: A88XM-E35 V2
Military Class 4 is the next step in high quality components. The Dark Choke and Solid CAP will make sure that your PC runs more stable under extreme gaming conditions.
Dark Choke uses the special core design and allows the Dark Choke to run at a lower temperature with higher capacity and better power efficiency and stability.
With their aluminum core design and Japanese made quality, Solid CAPs are made for high-end design motherboard. Not only do Solid CAPs could provide lower Equivalent Series Resistance (ESR), but also work firmly for over-10-year.
The core of Military Class 4 is based on the essentials which increase your stability in the worst conditions. The humidity protection and high temperature protection ensure your system surviving each environment, no matter how harsh. The structure of the PCB limits EMI radiation. On top of that all the connectors have ESD protection in order to prevent short circuit.
MSI A88XM-E35 V2 - motherboard - micro ATX - Socket FM2+ - AMD A88X
Motherboard - micro ATX
Chipset Type
AMD A88X
Processor Socket
1 x Socket FM2+
Compatible Processors
Athlon, A series
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
2048 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
AMD A88X
Processor Socket
Socket FM2+
Max Processors Qty
1
Athlon, A series
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1866 MHz, 2133 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP), AMD Memory Profile (AMP)
Graphics
2048 MB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111G
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 240-pin , 1 x PCIe 3.0 x16 (FM2+ processor must be installed) , 1 x PCIe 2.0 x1 , 1 x PCI
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
1 x PS/2 keyboard , 1 x HDMI , 1 x VGA , 1 x DVI-D , 4 x USB 2.0 , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x PS/2 mouse
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x parallel - header , 1 x serial - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Features
M-Flash, MSI ClickBIOS 4
Hardware Features
AMD Cool 'n' Quiet Technology, USB Safeguard, Intel Extreme Memory Profile (XMP) support, Super Charger, AMD Radeon Dual Graphics, AMD Memory Profile (AMP) support, MSI Military Class IV, Military Class Essentials, OC Genie 4, MSI Fast Boot
Software Included
MSI Live Update 6
22.6 cm
21.6 cm
