Product
Brand
MSI AMD FM2+ A88X DDR3 USB3.0 GBE LAN VGA DVI
Quicklinx: BDYKWS00 Mfr#: A88XM-P33 V2
No more seamless waiting for your O/S to be loaded! MSI Fast Boot helps to make your system boot lightning fast. MSI Fast Boot also features a GO2BIOS button. Simply click it to restart your PC and go straight to the system BIOS.
Dark Choke uses the special core design and allows the Dark Choke to run at a lower temperature with higher capacity and better power efficiency and stability.
With the one-second overclocking option OC Genie you get even more performance. Just hit the button and your PC gets another adrenalin shot straight away. Give your system an awesome performance boost with ease.
OC Genie supports 65W K-series APU only
MSI A88XM-P33 V2 - motherboard - micro ATX - Socket FM2+ - AMD A88X
Motherboard - micro ATX
Chipset Type
AMD A88X
Processor Socket
1 x Socket FM2+
Compatible Processors
Athlon, A series
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
4 x SATA-600 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
2048 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
AMD A88X
Processor Socket
Socket FM2+
Max Processors Qty
1
Athlon, A series
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1866 MHz, 2133 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP), AMD Memory Profile (AMP)
Graphics
2048 MB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111G
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 240-pin , 1 x PCIe 3.0 x16 (FM2+ processor must be installed) , 1 x PCIe 2.0 x1 , 1 x PCI
Storage Interfaces
SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
1 x PS/2 keyboard , 1 x VGA , 1 x DVI-D , 4 x USB 2.0 , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x PS/2 mouse
Internal Interfaces
4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x serial - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Features
M-Flash, MSI ClickBIOS 4
Hardware Features
AMD Cool 'n' Quiet Technology, USB Safeguard, Intel Extreme Memory Profile (XMP) support, Super Charger, AMD Radeon Dual Graphics, AMD Memory Profile (AMP) support, MSI Military Class IV, Military Class Essentials, OC Genie 4, MSI Fast Boot
Software Included
MSI Live Update 6
22.6 cm
21.6 cm
