MSI AMD FM2+ A68H DDR3 USB3.0 VGA HDMI DVI
Quicklinx: BDYHWS00 Mfr#: A68HM GRENADE
Dark Choke uses the special core design and allows the Dark Choke to run at a lower temperature with higher capacity and better power efficiency and stability. With their aluminum core design and Japanese made quality, Solid CAPs are made for high-end design motherboard. Not only do Solid CAPs could provide lower Equivalent Series Resistance (ESR), but also work firmly for over-10-year.
The MSI Click BIOS 4 is the latest UEFI BIOS with optimizations for Windows 8.1. Not only that it also reacts faster, runs smoother and has better mouse support. And this all comes with many cool features.
Compared to the 480Mbps provided by traditional USB 2.0, the all-new USB 3.0's 5Gb/s offers 10 times the transfer bandwidth, so transferring a Blu-ray movie takes less than one minute. SATA 6Gb/s provides double the bandwidth of traditional SATA 3Gb/s, and increases the data transfer rate between your motherboard and internal storage devices, such as 7200RPM HDDs, 10000RPM HDDs and SSDs. It's also the current trend for upcoming high-speed internal storage devices to break the existing bottleneck of a PC's performance.
AMD Cool'n'Quiet Technology reduces heat and noise so you can experience amazing performance without distraction. Combined with core enhancements, included in the AMD processors, that can improve overall power savings, deliver better multitasking and energy efficiency. Cool'n'Quiet technology can automatically adjust processor ratio to throttle CPU speed with four modes.
  • Dark Choke
  • Solid CAP
  • Click BIOS 4
  • USB 3.0
  • SATA 6Gb/s
  • AMD Cool'n'Quiet
  • HDMI
    Enjoy the awesome HD video playback now! MSI motherboards that are equipped with HDMI port support the latest and the most innovative signal outputs to provide an unprecedented visual experience.
MSI A68HM GRENADE - motherboard - micro ATX - Socket FM2 / FM2+ - AMD A68H
Motherboard - micro ATX
Chipset Type
AMD A68H
Processor Socket
1 x Socket FM2 / FM2+
Compatible Processors
Athlon, A series
Max RAM Size
32 GB
RAM Supported
2 DIMM slots non-ECC, unbuffered
Storage Ports
4 x SATA-600 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
2048 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Chipset Type
AMD A68H
Processor Socket
Socket FM2 / FM2+
Max Processors Qty
1
Athlon, A series
Supported RAM
Max Size
32 GB
Bus Clock
1600 MHz, 1333 MHz, 1866 MHz, 2133 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP), AMD Memory Profile (AMP)
Graphics
2048 MB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111G
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x1 , 1 x PCI
Storage Interfaces
SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10
1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x HDMI , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 2 x USB 3.0 , 1 x DVI-D
Internal Interfaces
1 x audio - header , 4 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x serial - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Features
M-Flash, UEFI BIOS, MSI ClickBIOS 4
Hardware Features
AMD Cool 'n' Quiet Technology, USB Safeguard, All-Solid Capacitor motherboard Design, Intel Extreme Memory Profile (XMP) support, MSI Winki 3, AMD Radeon Dual Graphics, Super Ferrite Choke (SFC), AMD Memory Profile (AMP) support, MSI Military Class IV, Military Class Essentials, MSI Fast Boot
Software Included
MSI Live Update 6
22.6 cm
18.6 cm
