MSI AMD AM3+ 970 4*DDR3 0/2*USB3.0
Quicklinx: CGXPWS00 Mfr#: 970A-G43 PLUS
MSI motherboards feature one or more PCI Express 2.0 slots, perfectly aligned and with enough space for an optimal airflow when using multiple graphics cards. That way, you will never have to worry about an overheating PC, while you are enjoying the best graphics jumping off from your monitor when running a AMD CrossFire gaming setup.
The core of Military Class 4 is based on the essentials which increase your stability in the worst conditions. The humidity protection and high temperature protection ensure your system surviving each environment, no matter how harsh. The structure of the PCB limits EMI radiation. On top of that all the connectors have ESD protection in order to prevent short circuit.
SATA 6 Gb/s provides double the bandwidth of traditional SATA 3Gb/s, and increases the data transfer rate between your motherboard and internal storage devices, such as 7200RPM HDDs, 10000RPM HDDs and SSDs. It's also the current trend for upcoming high-speed internal storage devices to break the existing bottleneck of a PC's performance.
MSI 970A-G43 PLUS - motherboard - ATX - Socket AM3+ - AMD 970
Motherboard - ATX
Chipset Type
AMD 970 / AMD SB950
Processor Socket
1 x Socket AM3+
Compatible Processors
Sempron, Athlon II, Phenom II, FX
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3
Storage Ports
6 x SATA-600 (RAID)
USB / FireWire Ports
2 x USB 3.1 Gen 2 + 6 x USB 2.0 + (2 x USB 3.1 Gen 1 + 6 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
AMD 970 / AMD SB950
Processor Socket
Socket AM3+
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2133 MHz (O.C.)
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111E
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 2.0 x16 (x16/x4 mode) , 2 x PCIe 2.0 x1 , 2 x PCI
Storage Interfaces
AMD SB950: SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x USB 3.1 Gen 2 , 6 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Internal Interfaces
1 x audio - header , 6 x USB 2.0 - header , 2 x USB 3.1 Gen 1 - header , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
DMI support, M-Flash, UEFI BIOS, MSI ClickBIOS 4
Hardware Features
AMD Cool 'n' Quiet Technology, USB Safeguard, All-Solid Capacitor motherboard Design, AMD CrossFireX technology support, MSI Military Class IV, Military Class Essentials, OC Genie 4, MSI Fast Boot, MSI Steel Armor
Software Included
MSI Command Center, MSI Live Update 6
Plug and Play
30.5 cm
22.5 cm
