MSI 970 GAMING AMD AM3+ 970+SB950 DDR3 USB 3.0 ATX
Quicklinx: 9L78WS00 Mfr#: 970 GAMING
970 GAMING: AMD 970 chipset based
  • Supports AMD FX / Phenom™ II / Athlon™ II / Sempron™ processors for AM3+ socket
  • Supports DDR3-2133(OC) Memory
  • USB 3.0 + SATA 6Gb/s
  • Audio Boost 2: Reward Your Ears with True Quality
  • Killer Ethernet: Kill Your Lag
  • OC Genie 4: Overclock in 1 Second
  • Click BIOS 4: Easily Fine-tune Your System
  • NVIDIA SLI & AMD CrossFire Support
  • Sound Blaster Cinema 2: Realistic Surround Sound Experience
  • Gaming Device Port: Optimized with Triple Gold-plating for High Polling Rate Gaming Devices
LET THE GAMES BEGIN
MSI® GAMING motherboards are designed to provide gamers with best-in-class features and technology. Backed by the imposing looks of MSI's Dragon, each motherboard is an engineering masterpiece tailored to gaming perfection.
THE BEST GAMING WEAPONS AT HAND
  • Amazing sound with Audio Boost 2, powered by Creative Sound Blaster Cinema 2
  • The highest frag and the lowest lag with Killer™ E2200 Game Networking
  • Military Class 4 components
  • Specialized production lines just for GAMING motherboards
  • OC Genie 4
  • Click BIOS 4 (click here to visit our dedicated BIOS page)
  • Optimized for multiple graphics cards (CrossFire certified)
  • Take control with Command Center & Live Update 6
REWARD YOUR EARS WITH TRUE QUALITY
Get ready for ear-drum shattering sound, with MSI Audio Boost 2! With Audio Boost 2 we're delivering the highest audio quality with the use of Creative Sound Blaster Cinema 2 so you can enjoy crystal clear sound and music through 8-channel HD Audio.
ISOLATED AUDIO PCB
With traditional onboard audio the signal is distorted by electromagnetic signals from the rest of the PCB. Audio Boost 2 acts like a dedicated soundcard by physically isolating the audio circuitry which is separated by a red LED path. Less interference gives you a more clear audio signal.
CREATIVE SOUND BLASTER CINEMA 2
Thanks to Creative Sound Blaster Cinema 2, you're getting amazing surround sound with just stereo headphones or speakers. Creative Sound Blaster Cinema 2 enables you to clearly hear specific sounds in gaming environments. Hear your enemies perfectly, make your ears a decisive tool to finish on top.
DUAL HEADHPONE AMPLIFIERS
Prepare for an eargasm. The built-in dual headphone amplifier rewards your high quality headphone with the most amazing studio level sound quality up to 600O delivered from your gaming PC.
Tired of having to connect your headset in difficult to reach places? MSI GAMING motherboards are designed to be easy to use, featuring front & rear audio outputs fueled by Audio Boost 2.
HIGH QUALITY AUDIO CAPACITORS
With the use of professional Nichicon Japanese capacitors, specially designed for audio purposes, MSI GAMING motherboards provide the highest possible audio signal filtering. Delivering high fidelity crystal clear sound with exceptional acoustics and realism.
  • Acoustic series
  • Lower Tolerance
  • Lower Dielectric Absorption
  • Lower ESR
  • Lower Leakage Current
  • Higher Stability
GOLDEN AUDIO CONNECTORS
With golden audio connectors you get the best possible signal output with less chance of distortion.
  • Up to 600O crystal clear sound with exceptional acoustics
  • Dedicated amplified output (red) optimized for studio-grade headgear
  • Superb signal conductivity and will not wear over time
KILLER™ E2200 GAME NETWORKING: KILL YOUR LAG!
The Killer™ E2200 Intelligent Networking Platform is built for maximum networking performance for online games and high-quality streaming media. Featuring Advanced Stream Detect™, Killer E2200 automatically detects and accelerates game traffic ahead of other network traffic for smoother, stutter-free in-game performance and the competitive edge. With this exclusive, automatic traffic prioritization, games and real-time chat get priority over low-level system chatter, giving you the lowest latency for game data on the most controllable network hardware available.
Specfiication
  • Socket AM3+
  • CPU (Max Support) FX
  • FSB/BCLK/Hyper Transport Bus up to 4.8GT/s
  • Chipset AMD® 970+SB950
  • DDR3 Memory DDR3 1066/1333/1600/1866/2133(OC)
  • Memory Channel Dual
  • DIMM Slots 4
  • Max Memory (GB) 32
  • PCI-Ex16 2
  • PCI-E Gen Gen2 (1x16, 1x8)
  • PCI-Ex1 2
  • PCI 2
  • SATAIII 6
  • RAID 0/1/5/10
  • TPM (header) 1
  • LAN 10/100/1000*1
  • USB 3.0 ports (Front) 2
  • USB 3.0 ports (Rear) 2
  • USB 2.0 ports (Front) 6
  • USB 2.0 ports (Rear) 8
  • Audio ports (Rear) 6
  • Form Factor ATX
  • APS Y
  • SLI Y
  • CrossFire Y
  • Reward your ears with true quality
    Get ready for ear-drum shattering sound, with MSI Audio Boost 2! With Audio Boost 2 MSI is delivering the highest audio quality with the use of Creative Sound Blaster Cinema 2 so you can enjoy crystal clear sound and music through 8-channel HD Audio.
  • Isolated audio PCB
    With traditional onboard audio the signal is distorted by electromagnetic signals from the rest of the PCB. Audio Boost 2 acts like a dedicated soundcard by physically isolating the audio circuitry which is separated by a red LED path. Less interference gives you a more clearly audio signal.
  • Creative Sound Blaster Cinema 2
    Thanks to Creative Sound Blaster Cinema 2, you're getting amazing surround sound with just stereo headphones or speakers. Creative Sound Blaster Cinema 2 enables you to clearly hear specific sounds in gaming environments. Hear your enemies perfectly; make your ears a decisive tool to finish on top.
  • Dual headhpone amplifiers
    Prepare for an eargasm. The built-in dual headphone amplifier rewards your high quality headphone with the most amazing studio level sound quality up to 600 O delivered from your gaming PC. Tired of having to connect your headset in difficult to reach places? MSI GAMING motherboards are designed to be easy to use, featuring front & rear audio outputs fueled by Audio Boost 2.
  • High quality audio capacitors
  • Killer E2200 Game networking
    The Killer E2200 intelligent networking platform is built for maximum networking performance for online games and high-quality streaming media. Featuring Advanced Stream Detect, Killer E2200 automatically detects and accelerates game traffic ahead of other network traffic for smoother, stutter-free in-game performance and the competitive edge. With this exclusive, automatic traffic prioritization, games and real-time chat get priority over low-level system chatter, giving you the lowest latency for game data on the most controllable network hardware available.
    Military Class 4 is the next step in high quality components. The Hi-c Cap, super ferrite choke and solid CAPs will make sure that your PC runs more stable under extreme gaming conditions.
  • Super ferrite chokes
    Super ferrite chokes use a ferrite core that is super-permeable. This allows the super ferrite chokes to run at a 35 degree Celsius lower temperature, have a 30% higher current capacity, a 20% improvement in power efficiency and better overclocking power stability.
  • Dark CAP
    With their aluminum core design, Dark CAP's have been a staple in high-end design mainboard designs and provides lower Equivalent Series Resistance (ESR) as well as its over-long-year lifespan.
  • OC Genie 4
    OC Genie is the world's first built-in hardware overclocking technology on motherboards. With this one-second overclocking option MSI is giving you even more performance. Just hit the button and your PC gets another adrenalin shot. Delivering up to 20% of free extra performance for the CPU, memory and iGPU.
    Get up to 2 PCI-Express 2.0 x 16 slots, with optimal placement for better fitting and airflow. That way, you can enjoy the best graphics at the highest framerate jumping off from your screen when running a NVIDIA SLI or AMD CrossFire gaming setup.
MSI 970 GAMING - motherboard - ATX - Socket AM3+ - AMD 970
Motherboard - ATX
Chipset Type
AMD 970 / AMD SB950
Processor Socket
1 x Socket AM3+
Compatible Processors
Sempron, Athlon II, Phenom II, FX
Data Bus Transfer Rate
4.8 GT/s
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3
Storage Ports
6 x SATA-600 (RAID)
USB / FireWire Ports
2 x USB 3.0 + 8 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Motherboard - ATX
Chipset Type
AMD 970 / AMD SB950
4.8 GT/s
Processor Socket
Socket AM3+
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz, 1866 MHz, 2133 MHz (O.C.)
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC1150
High Definition Audio, Sound Blaster Cinema 2
LAN
Network Controller
Killer Gaming E2205
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 1 x PCIe 2.0 x16 , 1 x PCIe 2.0 x16 (x8 mode) , 2 x PCIe 2.0 x1 , 2 x PCI
Storage Interfaces
AMD SB950: SATA-600 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
1 x TOSLINK , 1 x PS/2 keyboard / mouse , 2 x USB 3.0 , 8 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Internal Interfaces
1 x audio - header , 6 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x serial - header , 1 x SPDIF out - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Features
DMI support, UEFI BIOS, MSI ClickBIOS 4
Hardware Features
MSI Active Phase Switching (APS), NVIDIA 2-way SLI Technology Support, Super Ferrite Choke (SFC), AMD CrossFireX technology support, Hyper Transport 3.0, MSI Military Class IV, OC Genie 4, MSI Gaming Device Port, MSI Audio Boost 2
"Do-Not-Disturb" door hanger, case badge, cable labels
Software Included
MSI Command Center, RAMdisk, MSI Live Update 6
Plug and Play
30.5 cm
24.4 cm
