Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
G0ZH 043239 Condition: Customer return - item has been opened but is in excellent condition |
£108.88 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
