Your basket is empty
Motorola Symbol DS7708 Vertical Slot Scanner
Quicklinx: BV2YWS00 Mfr#: DS7708-SR4U2100ZCW
Type: Barcode scanner
Form Factor: Desktop
Compatibility: PC
£244.12 ex VAT
£292.94 inc VAT
When it comes to on-counter scanning, the 2-D imager-based DS7708 offers a feature set that puts it at the top of its class for performance, ease of use, easy deployment and total cost of ownership. With a field of view that is over 50 percent larger than the competition, barcodes are easily captured, regardless of where they are located on an item. No matter what barcodes appear at your POS, the DS7708 can scan them all - 1-D, 2-D, printed and electronic. The result? Your cashiers can scan items as fast as they can slide them past the scan window for lightning fast checkout. The compact design makes installation a breeze, even in the most space constrained checkout lanes. And extraordinary durability minimizes costs and protects uptime, maximizing device lifecycle - and your return on investment.
Symbol DS7708-SR - barcode scanner
Barcode scanner - desktop - USB - decoded
Minimum Bar Width
3 mil
Scan Element Type
2D imager
Sensor Resolution
1280 x 960
Scan Speed
2540 mm / sec
Wired
14.9 cm x 9.7 cm x 14.3 cm
500 g
3 years warranty
Midnight black
Barcode
Interface Type
USB
Minimum Bar Width
3 mil
Scan Element Type
2D imager
Sensor Resolution
1280 x 960
Light Source Wave Length
660 nm
Scan Mode
Single-pass
Scan Speed
2540 mm / sec
Max Working Distance
26.1 cm
Skew (Degrees)
70
Pitch (Degrees)
70
Print Contrast Signal (PCS)
25%
Decode Capability
EAN/JAN, Code 93, Code 39, NW-7, GS1 DataBar, QR code, MaxiCode, Aztec code, MicroPDF417, Italy Pharmacode, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, PDF417, MSI-Plessey, Data Matrix, TLC39, Micro QR code, China Han Xin Code
TTL Decoding
Decoded
Wired
OK Notification
Beeper, LED indicator
Checkpoint Electronic Article Surveillance (EAS)
1 x USB
1 x USB cable - external
EN 61000-4-2, IP52
14.9 cm
9.7 cm
14.3 cm
500 g
Limited warranty - 3 years
5 - 85% (non-condensing)
Drop Specification
1.5 m to concrete
Compatibility: PC
Brand: Motorola
Price Range Ex VAT: 150 - 300
