Zebra MC55 LP 1D CAM VGA QTY
NEED A MOBILE TARIFF ??? SEE DESCRIPTION BELOW
Quicklinx: 7Z2SWS00 Mfr#: MC55A0-P90SWQQA9WR
Give managers and task workers everything they need to take instant action anywhere. Pure business on the inside and smart styling on the outside, the MC55A0 rugged mobile computer for enterprise lets your workers access business applications, scan barcodes, snap a photo, view a video and place a private or push-to-talk call to virtually anyone in your facility – all with a single device. The sleek lightweight design is not only pocketable, it is at home in front of customers and patients. And government grade FIPS 140-2 security keeps your most sensitive data safe and secure.
  • Drive productivity and efficiency inside the enterprise to an advanced level
    With the MC55A0 series, managers and task workers who spend their days inside your company walls have everything they need to take instant action, anywhere in your facility - indoors and outside. When it comes to meeting the needs of your workforce, the MC55A0 excels, offering the right level of features, the right level of rugged design and support for the most demanding business applications. Workers in retail, hospitality, manufacturing, healthcare and government agencies can complete more tasks more accurately in less time, improving productivity and customer care. MC55A0-HC brings mobility to point-of-care applications, helping nurses and other caregivers eliminate errors at the patient bedside to improve the quality of care - and the patient experience.
  • Pure business on the inside - smart styling on the outside
    The MC55A0 series is the perfect blend of form and function. The comprehensive capabilities allow workers to scan bar codes; snap pictures; view videos; access business applications, the Internet and email as well as make and receive private and push-to-talk voice calls. The compact and lightweight mobile computer is easy to carry and easy to use, with a sleek design that is equally at home in front of customers and patients.
  • Rugged design
    The MC55A0 series gives workers a device they can count on and businesses a maximum return on investment (ROI). This rugged device family is built for use inside your buildings as well as outdoor areas of your facilities - and our toughness tests prove it. The MC55A0 delivers outstanding performance, even after exposure to heat, cold, dust, water. And the models can be sanitized with many common cleaners without harming the housing or the sensitive electronics, helping prevent the spread of bacteria to patients and caregivers in a hospital as well as shift workers in other industries where devices are shared.
  • Unparalleled voice functionality and quality
    The MC55A0 is designed from the ground up to enable voice as well as data over your WLAN. The result is a great user experience, highly cost-effective voice communications and a broad voice feature set. Start with the ability to turn the MC55A0 into a mobile version of your deskphones. Then add a push-to-talk connection to practically any other Zebra mobile device, including other mobile computers, EAM smartphones and even two-way radios on completely different networks. This powerful combination allows workers to place one-to-one calls in sensitive environments, such as healthcare, while retail and other managers can easily reach an entire workgroup at the press of a button - eliminating intrusive overhead paging systems that affect the customer experience. Handset and speakerphone modes allow workers to choose privacy or hands-free convenience, meeting the needs of the job and the moment. And since voice and data services are delivered over the WLAN, in-building cellular coverage issues that can affect voice quality are eliminated.
Zebra MC55A0 - Enterprise - data collection terminal - Win Mobile 6.5 Classic - 1 GB - 3.5"
Data collection terminal - rugged
Operating System
Microsoft Windows Mobile 6.5 Classic
Display
3.5" colour LED backlight - 640 x 480
Marvell XScale PXA320
Processor Clock Speed
806 MHz
Storage
1 GB
RAM
256 MB
Supported Flash Memory Cards
microSD, microSDHC
Wireless Connectivity
802.11a/b/g, Bluetooth 2.1 EDR
Rear Camera
3.2 Megapixel
Barcode Reader
Yes (laser)
Extended capacity battery
7.7 cm x 2.7 cm x 14.7 cm
315 g
1-year warranty
Operating System
Display
3.5" colour - LED backlight
Resolution
640 x 480
806 MHz
Storage
1 GB
RAM
256 MB
microSD, microSDHC
Max Supported Capacity
32 GB
Communications
Security Protocols & Features
LEAP, WEP, TLS, WPA2, TKIP
Rear Camera
Sensor Resolution
3.2 Megapixel
Multimedia
Audio
Microphone, speaker
Input Device
Touch-screen, QWERTY keyboard
Barcodes
Barcode Reader
Scan Element Type
Laser
Minimum Bar Width
0.127 mm
Expansion and Connectivity
Expansion Slots
1 x microSD
1 x USB
Extended capacity battery - Lithium Ion
3600 mAh
Sensors
Accelerometer
LED indicator
cUL, EN55022 Class B, ICES-003 Class B, FCC Part 15 B, FCC Part 15.247, OET 65 C, RSS-210, RSS-102, RoHS, FIPS 140-2, FCC Part 2, UL 60950-1, EN 60950-1, AS/NZS 4268, MIL-STD 810G, RSS-310, IP64, IEC 60825-1, FCC Part 15.407, EN 60601-1-2, ARIB STD-T66, ARIB STD-T70, ARIB STD-T71, ARIB STD-T33, CCX V4, EN 60825-1, EN 50392, EN 300 328, EN 301 489-1, EN 301 893, EN 301 489-19, EN 300 440-2, EN 301 489-17
7.7 cm
2.7 cm
14.7 cm
315 g
Limited warranty - 1 year
-10 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
