Your basket is empty
Motorola LS4208 BLK USB A 7 FT Barcode Scanner
Quicklinx: 85LDWS00 Mfr#: LS4208-SBZU0100TR
Type: Barcode scanner
Form Factor: Handheld
Compatibility: PC
More than 50 in stock
£99.36 ex VAT
£119.23 inc VAT
The Symbol LS4208 handheld laser scanner delivers exceptional performance in an accesible, intuitive package. Its single-circuit board design ensures sturdiness and an ergonomic shape maximizes user comfort. Continuous one-pass scanning, an innovative multi-line rastering scan pattern, a wide working range and superior motion tolerance make data capture easy, even for novices.
Symbol LS4208 - barcode scanner
Barcode scanner - handheld - USB - decoded
EMEA
Minimum Bar Width
5 mil
Scan Element Type
Visible laser diode
Wired
6.8 cm x 9.3 cm x 17 cm
181 g
5 years warranty
EMEA
Barcode
Interface Type
USB
Minimum Bar Width
5 mil
Scan Element Type
Visible laser diode
Light Source Wave Length
650 nm
Scan Mode
Single-pass
Max Working Distance
0.7 m
Pitch (Degrees)
60
Print Contrast Signal (PCS)
25%
Decode Capability
Code 93, Code 39, UCC/EAN-128, IATA, RSS Code, Bookland, Code 32, Code 39 Full ASCII, Discrete 2 of 5, Codabar, Code 128, UPC, Interleaved 2 of 5, Code 128 Full ASCII, Code 39 Trioptic
TTL Decoding
Decoded
Wired
1 x USB
Stand
1 x USB cable - external
FCC Class B certified, EN 60950, UL 1950, IEC 60950, CSA 22.2 No. 950, EMC, FCC Part 15
6.8 cm
9.3 cm
17 cm
181 g
5 years warranty
Service & Support Details
Limited warranty - 5 years
50 °C
5 - 95%
Drop Specification
1.8 m to concrete
Compatibility: PC
Brand: Motorola
Price Range Ex VAT: 50 - 100
