Your basket is empty
Motorola CS3000, BT,1D, USB Kit, Black
Quicklinx: 8SS2WS00 Mfr#: CS3070-SR10007WW
Type: Barcode scanner
Form Factor: Portable
Compatibility: PC
More than 50 in stock
£135.26 ex VAT
£162.31 inc VAT
The Motorola CS3000 Series enables enterprises to easily implement 1D laser scanning where either mobility or the cost and size of a traditional scanning device is an inhibitor. The tiny device fits in a pocket or on a lanyard. The CS3070 offers batch mode as well as real-time bar code data transmission to a host application via a wireless Bluetooth connection to smartphones, laptops and more. The result is a high level of affordability for 1D scanning - and the ability to streamline, error-proof and simplify more business processes.
Motorola CS3000 Series CS3070 - barcode scanner
Barcode scanner - portable - Bluetooth 2.1 EDR - decoded
Scan Element Type
Laser
Wireless
Wireless Connectivity
Bluetooth 2.1 EDR
1 x Lithium Ion
5 cm x 8.7 cm x 2.2 cm
70 g
1 year warranty
Barcode
Interface Type
Bluetooth 2.1 EDR
Scan Element Type
Laser
Scan Mode
Single-pass
TTL Decoding
Decoded
Wireless
OK Notification
LED indicator
Bluetooth 2.1 EDR
Flash
512 MB
1 x USB 2.0
1 x USB cable
RoHS, IEC 60529 IP40
Power adapter - external
1 x Lithium Ion
5 cm
8.7 cm
2.2 cm
70 g
1 year warranty
Service & Support Details
Limited warranty - 1 year
10 - 95%
Drop Specification
1.2 m to concrete
Compatibility: PC
Brand: Motorola
Price Range Ex VAT: 100 - 150
