The AP 7532 802.11ac access point adds bandwidth and performance to your network - a must for supporting high-density traffic from laptops, tablets, smartphones and other devices - while delivering advanced security options. Configure the AP 7532 to act as an in-line sensor for client location awareness and as a tool for security threat analysis, or dedicate a single unit to a security role full-time for greater power and performance. This is the type of flexibility network managers will appreciate when designing your secure network.
Unmatched bandwidth for unmatched network and application performance
Multiple-Input Multiple-Output (MIMO) allows 3-spatial streams of data to be sent simultaneously to a single mobile device, substantially improving bandwidth efficiency and utilization. 256 QAM modulation gives the 802.11ac radio an additional performance boost, and works hand-in-hand with MIMO technology to boost the bandwidth of the 802.11n radio to 802.11ac speeds. Since 802.11ac operates only in the 5 GHz band, interference from 2.4 GHz devices is finally eliminated - from Bluetooth headsets to microwave ovens. The result? Your WLAN can support an unprecedented number of users and applications. -
More robust wireless connections
Your users will experience a more robust wireless connection than ever before, thanks to improved beamforming. Beamforming creates efficient path for data transmission between an access point and a mobile device. Until today, the transmitting beamformer worked alone to define this path. Now, the receiver also assists, a process known as sounding. The result is a stronger connection that enables faster data transmission. Application throughput and performance are improved, along with mobile device battery power. -
Voice, locationing, and guest access
Support for Voice-over-wireless LAN (VoWLAN) quality of service (QoS) ensures toll quality, even with many simultaneous calls on a single access point. In addition, you can leverage locationing services to locate and track people and assets, as well as control network and application access. And since you can ensure that users are only able to access authorized networks, sites, and applications, it's easy to provide hotspot and guest access.
- Extreme Networks AP 7532 - radio access point - Wi-Fi 5
- Radio access point
- Form Factor
- External
- Localisation
- Europe
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Power Over Ethernet (PoE) Supported
- PoE
- 16.5 cm x 18 cm x 4.1 cm
- 820 g
- 16.5 cm
- 18 cm
- 4.1 cm
- 820 g
- Localisation
- Europe
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1.9 Gbps
- Line Coding Format
- 256 QAM
- Spread Spectrum Method
- OFDM, DSSS
- PPPoE, BOOTP
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Link/activity
- Firewall protection, routing, auto-sensing per device, DHCP support, power over Ethernet (PoE), VPN support, BOOTP support, load balancing, Stateful Packet Inspection (SPI), dynamic DNS server, DiffServ support, IP address filtering, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), roaming function, DHCP server, LLDP support, 3T3R MIMO technology, Low Density Parity Check (LDPC), Space Time Blocking Code (STBC), ceiling mountable, Type of Service (ToS)
- Encryption Algorithm
- WPA, WPA2
- Authentication Method
- RADIUS
- IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 801.1p, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
Aerial
- Antenna
- External detachable
- Antenna Qty
- 3
- Directivity
- Omni-directional
- 1 x 1000Base-T - RJ-45 , 3 x aerial - RP-SMA , 1 x management - RJ-45
- UL, cUL, UL 2043, RoHS, EN 60950-1, TELEC, cUL No.60950-1
- PoE
- OS Provided
- WiNG 5
- -20 °C
- 40 °C
